Zeder Geschrieben 18. April 2018 Geschrieben 18. April 2018 Hallo, Ich habe 2 PC's, beide mit Windows7 und firefox-Browser. Einer davon hat 32Bit System, der andere 64bit. Auf dem 32Bit funktioniert die 3D-View nicht. Es kommen dann Fehlermeldungen, die ich hier aufliste. Habe keine Ahnung was die Ursache sein könnte. 3D-View Klick Meldung 1 BROWSER COMPATIBILITY WARNING 3D view is not compatible with your current web browser. Some functionality may not work as intended or may cause your browser to crash. We recommend installing Google Chrome for best experience. Starte dann 3D trotzdem Meldung 2 We are sorry 3D view has stopped working. Please close and reopen 3D view to resume. If this happens again we suggest lowering your quality settings or try another browser Error constructing CesiumWidget. Visit http://get.webgl.org to verify that your web browser and hardware support WebGL. Consider trying a different web browser or updating your video drivers. Detailed error information is below: RuntimeError: The browser supports WebGL, but initialization failed. t@https://www.flightradar24.com/static/js/cesium/latest/Cesium.js?1523879751:1:61127 M@https://www.flightradar24.com/static/js/cesium/latest/Cesium.js?1523879751:1:1655785 we@https://www.flightradar24.com/static/js/cesium/latest/Cesium.js?1523879751:1:2338507 x@https://www.flightradar24.com/static/js/cesium/latest/Cesium.js?1523879751:1:2731848 K@https://www.flightradar24.com/static/js/cesium/latest/Cesium.js?1523879751:1:2817593 createViewer@https://www.flightradar24.com/static/js/cockpit_view.js?1523879751:1:1534 CesiumCockpit@https://www.flightradar24.com/static/js/cockpit_view.js?1523879751:1:61 CesiumCockpitViewModel/<@https://www.flightradar24.com/static/js/cockpit_view.js?1523879751:1:25551 dispatch@https://ajax.googleapis.com/ajax/libs/jquery/2.2.0/jquery.min.js:3:7467 add/r.handle@https://ajax.googleapis.com/ajax/libs/jquery/2.2.0/jquery.min.js:3:5583 Flightradar beendet. Bin froh um jeden Tipp Danke Zitieren
ArminZ Geschrieben 19. April 2018 Geschrieben 19. April 2018 (bearbeitet) Wie sieht es aus wenn Du auf die angegebene web page https://get.webgl.org gehst? Siehst du den drehenden Würfel? Ein sehr ähnliches Problem hier (siehe Kommentar von Scott Hunter). Könnte also auch an den Treibern liegen. Falls nicht schon probiert ->"Visit the support site for your browser" auf der webgl.org Seite. Hast du ev. schon einen anderen Browser ausprobiert? Bearbeitet 19. April 2018 von ArminZ Zitieren
Zeder Geschrieben 19. April 2018 Autor Geschrieben 19. April 2018 (bearbeitet) Hi Armin, Danke für die Tipps, die ich befolgt habe. get.webgl.org dann kommt diese Meldung Hmm. While your browser seems to support WebGL, it is disabled or unavailable. If possible, please ensure that you are running the latest drivers for your video card.For more help, please click this link.Check out some of the following links to learn more about WebGL and to find more web applications using WebGL. WebGL WikiWant more information about WebGL?khronos.org/webglHosted by Digital Ocean Dann habe ich gefunden über webgl die Info und ausgeführt: über about:config >> Webgl.disabled > true gesetzt Und Google_Chrome installiert wie geraten wird, gleiches Bild >> diese Meldung The browser supports WebGL, but initialization failed Wie ich das beheben kann, keine Ahnung... Schliesslich noch die VideoCard treiber updated Hier die Daten Standard-VGA-GrafikkarteTreiberdatei C:\Windows\system32\DRIVERS\vgapnp.sysDateiversion 6.1.7600.16835 (win7_rtm.090713-1255) Es ist halt eine etwas 'ältere' Karte und möglicherweise nicht 3D fähig. Wenn das so sein sollte, was ich nicht weiss, so lasse ich es dabei bleiben. Jedenfalls jetzt schon ein grosses Dankeschön für deine Hilfe. Gruss Bearbeitet 19. April 2018 von Zeder Zitieren
ArminZ Geschrieben 19. April 2018 Geschrieben 19. April 2018 Ich tippe auch auf die Treiber, kann aber leider auch nicht viel weiterhelfen Zitieren
Zeder Geschrieben 22. April 2018 Autor Geschrieben 22. April 2018 Hi Armin, Noch was dazu. Wenn ich diesen Link (Rubic-Würfel) lade, so kann ich die Ebenen drehen, dh. Webgl funktioniert. Ist noch tricky finde ich. Aber ich bin jetzt im Flightradar24-Forum aktiv ... Schönen Sonntag Ruedi Zitieren
