Beta 3 ist raus
Release Notes
Public Beta 3
Key Features & Improvements
  • XPD-7219 3rd party plugin brakes fixed.
  • Networking, crash, and joystick fixes.
  • New electrical system model changes.
  • XPLMNavigation API should work for third party plugins.
  • XPD-7070 Provide plugin per frame callouts even when paused.
  • Changes to .sit and .rep file types to make them stable across updates.
  • Pilot defined waypoints saved by the FMC now go into the user_fix.dat.
  • FMS will now correctly use GPS alt or barometric altitude for approach VNAV as per approach setting. Default is GPS altitude as for LPV approaches.
  • FMS fixes when using VNAV.
  • Backward compatibility in ARINC 424 interpreter.
  • Free global resources at program end to avoid memory leak false positives.
  • Fixed crash when loading DSFs while flying really, really fast.
  • Updated tire model.
  • A fix for weapons that have OBJs but not custom particle effects.
Additional Bug Fixes
  • XPD-7289 IP address of receiving network data was wrong.
  • XPD-7288 IPs are sorted in order and fixes missing IP address list.
  • XPD-7203 Crash with Open Air file.
  • XPD-7078 Fix for non-fogged interior objects.
  • XPD-7091 Failures now get applied only for the aircraft you set them on.
  • XPD-6851 Fix sky color through alpha texture in HDR mode.
  • XPD-6958 Changing plane altitude or speed in map changes heading as well.
  • XPD-7281 We now explicitly support approach targets that are not in our “nearby approaches” list.
  • XPD-7217 We can now separate the enum and order of the API.
  • XPD-6863 Take windows down to windowed mode before destroying them.
  • XPD-7060 Fix dev assert reloading 737.
  • XPD-7249 Fix for crash when you add a monitor while looking at Settings > Graphics.
  • XPD-7273 Updates to KSEA demo area.
  • XPD-7271 Removes G1000 C172 from installs.
  • XPD-7252 Update to LOWI demo area.
  • XPD-7064 Added ability to bind hat switches to any command, not just our suggested ones.
  • XPD-7061 Fix for setting aircraft heading via the inspector being wonky due to live editing the text field.
  • XPD-7268 Remove separate selection style from map.
  • XPD-7009 We now hide localizers in the map view that might interfere with seeing your “target” ILS.
  • XPD-7159 We can now select an approach at any time, and we no longer show downwind ILSes if applicable.
  • XPD-7245 Fixes dragging the plane icon on map when not paused.
  • XPD-7246 Tow plane does not tow us on the runway.
  • XPD-7256 Landing light switch dataref is a float.
  • XPD-7254 Fix for ATC window crashing when in “AI Flies Your Plane” mode.
  • XPD-7251 fix for crash in r-tree when the r-tree is empty.
  • XPD-7227 Fixed autobrakes.
  • XPD-7110 Stopped hover help tips from getting repositioned.
  • XPD-7221 Determine if an aircraft supports 2-D panel mode.
  • XPD-7236 Search in the command mappings table now includes children of matched folder.
  • XPD-7154 Fix for windowed -> fullscreen -> windowed transition increasing the window size and moving it.
  • XPD-7232 Fix for failures trashing your currently-loaded aircraft’s livery.
  • XPD-7210 Fix for crash when loading a bad .sit file in quickflight mode.
  • XPD-7211 Fix for crash caused by trying to load airport from prefs that no longer exists in your installation.
  • XPD-7212, XPD-7228 GPS has a problem with “degenerate” STARs that only consist of transition segments and no trunk route.
  • XPD-7233 Crash when changing location with IOS.
  • XPD-7032 Fix for “manual” network connections defaulting to port 0.
  • XPD-7186  Center map on PPOS if empty flight plan is viewed in PLN mode.
  • XPD-7193 Fix for missing NDB or VOR in flight plan.
  • XPD-7018 Restored ability for “optional” dialogs to be auto-dismissed on external visuals & machines under IOS control.
  • XPD-7083 We only display the “Save Configuration as Default” button if you do not have an image mapping for this joystick.
  • XPD-7044 Fix for incorrectly identifying monitor resolution when using mixed DPI displays.
  • XPD-7088 We now read your language prefs before falling back to prompting you to pick a language.
  • XPD-7184 AI can fly your aircraft again.
  • XPD-7220 Additional sounds added to C172 cockpit.
  • XPD-7250 Push-back working for AI aircraft.
  • XPD-7160 Stop labeling both ends of helipads in the map.
Updater starten !
Schöne Festtag
