pinball Geschrieben 2. Juli 2016 Geschrieben 2. Juli 2016 Heute ist die Edelweiß mach Havanna rückgelandet - weiß jemand, was genau passiert war? HB-JHQ wurde anscheinend nach der Landung von der Piste geschleppt. Zitieren
F-LSZH Geschrieben 2. Juli 2016 Geschrieben 2. Juli 2016 Hydraulikproblem lt. Avherald. An Edelweiss Airbus A330-300, registration HB-JHQ performing flight WK-32 from Zurich (Switzerland) to Havana (Cuba), was climbing through FL290 out of Zurich about 30nm west of Geneva (Switzerland) when the crew reported a hydraulic failure affecting flaps and possibly nose wheel steering and decided to return to Zurich. On approach to Zurich the crew requested a long final approach to have time to set their flaps and requested a tow truck available in case they needed to be towed. The aircraft performed an alternate gear extension (gear doors open) and landed safely on Zurich's runway 16 about 55 minutes after the decision to return to Zurich, stopped on the runway, shut the engines down and was towed to the apron. Zitieren
N251AY Geschrieben 3. Juli 2016 Geschrieben 3. Juli 2016 Ist nach wenigen Stunden wieder gestartet, war also nicht so gravierend. Zitieren
