Aerosoft Airbus Updates / Hotfixes
Und weiter geht's mit Hotfix 1.30c für den A320/319 von Aerosoft.......
___________________________________________________________________________________________________________________________________
This hotfix is intended to solve some open issues that popped up after the release of version 1.30 (Service Pack 3).
It includes hotfixes 1.30a and 1.30b
* Fixed autothrottle issues found on some systems
* Missing INI issue corrected
* Some co-pilot sound tweaks
* Minor CFD changes
* Vol 1 manual updated
* N1 issue fixed
* APU Save/Load fix
* CFD Port Setting Fixed - http://forum.aerosof...ectionproblems/
* ATHR more minor refinments.
* Airspeed trend vectors now smoothened to help unrealistic turb.
* ND: "DECEL" pseudo waypoint enhanced by white symbol.
* Model issue VC 321 fixed: http://forum.aerosof...in-the-cockpit/
As this is a zip file the issue with RAAS not being installed is not corrected. Follow this:
zip.gif  A320_130c_Hotfix.zip   11.86MB   1194 Number of downloads
Hotfixes are intended to share the files we are have tested internally. They are NOT complete releases and use is on your own risk. They ARE supported via the forums, not via email or telephone.
Installation
  1. Close FSX/P3D.
  2. Reboot your system
  3. Login with Administration rights
  4. Unpack the attached zip to a folder on your system. You will find two folders, FSXMainFolder and UserFolder
  5. Copy the content of the FSXMainFolder to your FSX/P3D main folder.
  6. Overwrite all existing files.
  7. If you are NOT asked if files can be overwritten you are most likely not copying to the correct Folder.
Wieder ein neuer Hotfix für die Aerosoft Airbusse, jetzt jeweils Hotfix1.30e für 318/319 und 320/321(beinhaltet a-d)!
It includes hotfixes 1.30a, 1.30b, 1.30c and 1.30d
* Fixes several CFD issues introduced in 1.30d due to wrong upload of files.
* Possible fix to Go Around issue
* Minor CFD changes
* N1 issue fixed
* APU Save/Load fix
zip.gif  A320_130e_Hotfix.zip   11.97MB   4788 Number of downloads
Installation
  1. Close FSX/P3D.
  7. If you are NOT asked if files can be overwritten you are most likely not copying to the correct folder.
