Speedbrake armed annunciator 737
hercules123
Hallo Bobby Riders,
ist es korrekt, dass der Speedbrake armed Annunciator auch leuchtet, wenn der Level hinter der armed Position steht und die Speedbrake dann auch ausfahren beim Touchdown?
Mir hinter meine ich in Richtung up
Best Regards/ Beste Grüße
Thomas
Bearbeitet von hercules123
Ohne vorgreifen zu wollen, aber ich richte das gerade ein.
737 Flight Crew Operations Manual
SPEED BRAKE Lever
DOWN (detent) – all flight and ground spoiler panels in faired position.
ARMED –
• automatic speed brake system armed
• upon touchdown, the SPEED BRAKE lever moves to the UP position,
and all flight and ground spoilers extend.
FLIGHT DETENT – all flight spoilers are extended to their maximum position for
inflight use.
UP – all flight and ground spoilers are extended to their maximum position for
ground use.
2 SPEED BRAKE ARMED Light
Light deactivated when SPEED BRAKE lever is in the DOWN position.
Illuminated (green) – indicates valid automatic speed brake system inputs.
3 SPEED BRAKE DO NOT ARM Light
ARMED
DOWN
Illuminated (amber) –
• indicates abnormal condition or test inputs to the automatic speed brake
system
4 SPEEDBRAKES EXTENDED Light
• in–flight -
• SPEED BRAKE lever is beyond the ARMED position, and
• TE flaps extended more than flaps 10, or
• radio altitude less than 800 feet
• on the ground -
• SPEED BRAKE lever is in the DOWN detent,
• ground spoilers are not stowed.
Note: On the ground, the SPEEDBRAKES EXTENDED light does not
illuminate when hydraulic system A pressure is less than 750 psi.
