Verkaufen AHRS G mini (AW)
ich habe kürzlich von den machern von Air Nav Pro zu testzwecken (aufbau eines iPad kurses) ein kaum gebrauchten Levil AHRS G mini (AW) erworben. meine tests und kursunterlagen sind nun abgeschlossen, entsprechend verkaufe ich das AHRS:
"The AHRS-G mini is a battery powered attitude and heading reference system that provides pitch and bank information as well as magnetic heading, inclination, gravity load and yaw rate wirelessly to your portable device. Unlike the gyros inside your iPad or other similar systems, the AHRS-G mini is the only AHRS system that guarantees a Zero drift per hour rating. Meaning there is no calibration required at any point. Just set it on a level surface and you can count on an accurate horizon for the rest of the flight.
There are 2 models available, AHRS-G mini AW includes an air data computer which can be attached to the pitot static system of the aircraft. Note: General Aviation aircraft are not allowed to modify their pitot static system, therefore model SW is recommended."
http://www.aviation.levil.com/AHRS_mini.htm
das modell is das AW modell (mit air data integration), also speziell geeignet für ULs oder experimentals.
neupreis: $995
von vorgänger (air nav pro) neu erworben im mai 2012.
verkaufspreis: CHF 700 (incl. shipping in der schweiz).
let me know by PM.
  • 4 Wochen später...
