FSX Altenrhein FSX Scenery
Johan "Bigfoot"
Fur denn Altenrhein Fans.
Heute gesehen: http://www.aviationmegastore.com/altenrhein-x-7640101480719-aerosoft-7640101480719-sceneries/product/?shopid=LM4f5540e60a1fe641a941494d84&action=prodinfo&parent_id=0&art=106324
Gruss Bigfoot :cool:
Product description:
Start your engines and head to Altenrhein. This is a completely new development, which has been created with 3dsmax and shows the airport of Altenrhein with all its buildings, facilities and additional night lighting. All building`s textures have been created on the basis of more than 2000 images.
There are countless objects such as taxiway- and runway signs, position lights, approach lights, ILS facilities, and hangar signs, which all have been created in 3D. Using the NAV1 frequency you can even control the gate between the southern and northern maintenance areas. The ground textures have a resolution of 25cm/pixel and have been adapted to match the colors of Switzerland Professional X and Flight Simulator X. The famous AESLite tool of Oliver Pabst animates the AI-Traffic and provides traffic with moving vehicles.
History:
The airport of St. Gallen Altenrhein has a long and interesting history. In the strict sense, it goes back to 1926, when Claude Dornier decided to build up his aircraft manufacturing company at this location. For almost 30 years, the airport was contempt with only a 600m long grass runway before the Swiss federation started to use this airport for the Air Force – though only for maintenance. With this decision, a new 1200m long asphalt runway was built. The maintenance of the hunter fleet then required a lengthening of the runway to 1500m which has been completed in 1979.
As the contract for the hunter maintenance expired 1993 Altenrhein needed to invest in the civil aviation. This has been done by multiple expansions including a new terminal, new maintenance buildings and wider taxiways. Due to differing opinions the airport decided to cancel the cooperation with AUA and start services to Vienna with an own airline. As of March 2011 the People’s Vienna Line is in the air with a twice daily service to Vienna.
Video:
Highlights:
Highly detailed airport scenery of St. Gallen-Altenrhein, optimized for FSX
Realistic night effects
Complete 3D-models with high resolution photo textures
Very accurate buildings with a lot of details
Static Embraer 170 with «People`s Vienna Line» livery
Car traffic around the airport
AESLite for AI-Traffic and airport ground traffic
Trees around the airport with seasonal textures
Distinctive buildings in the surrounding area like Stadler-Rail or Altenrhein-Park
Charts to print: ILS, SID, STAR, VFR und Ground
Perfectly embedded into Switzerland Professional X
Enhanced Autogen in the airport’s area
Compatible with Switzerland Professional X, Ultimate Terrain X and FS Global 2010
System requirements:
Microsoft Flight Simulator X (SP2, Acceleration Pack or Gold Edition)
Windows XP/Vista/Win 7
2.66 GHz Processor (Dual Core Processor recommended)
2 GB RAM
Graphics card with at least 256 MB (512 MB recommended)
Schlachter Andreas
Danke für die Info. Habe die Neuerscheinung von Altenrhein X vor gut zwei Wochen bei Aerosoft entdeckt. Die Vorschaubilder mögen ja überzeugen. Aber eines stört mich mehr als denn je.
Es wurde mal wieder nur für den FSX gebaut. Sicherlich hat der Xer viel mehr Möglichkeiten als der FS9. Aber von Entwicklerseite den FS9 ganz zu ignorieren und der Meinung sein, dass dieser gar nicht mehr von den Usern verwendet wird, ist schon mehr als nur traurig.
Friedrichshafen X wurde zum Gegensatz dazu für beide Flusi entwickelt. Wenigstens hier wissen die Entwickler, dass es noch unzählige User gibt, die den FS9 benutzen.
Aber vielleicht erleben wir ja mit Aufkommen des FS Flight dann ähnliches, wenn nichts mehr für den 9er und Xer produziert wird.
  • 1 Monat später...
Hallo Andreas,
grundsätzlich gebe ich Dir recht, suche mir gerade für den FS Szenen zusammen, scheint ein Kampf gegen Windmühlen zu sein. Warum wird nicht mehr, sowohl für FSX als auch für FS9 im schönen Schwitzer Ländli gewerkelt, ich denke, das es nichts schöneres gibt. Altenrhein gibt es aber für 9 Euronen bei Flylogic.
Bodo
Schlachter Andreas
Ist aber auch in die Jahre gekommen.
Schöne wäre, wenn doch noch die FSX Version auch noch für den FS9 erstellt würde.
