Robin14 Geschrieben 25. Dezember 2009 Geschrieben 25. Dezember 2009 Hallo Leute, ich wollte gerade ein Repaint für dei Twin Otter von Aerosoft installieren. Beim letzten Punkt in der readme habe ich jedoch Probleme: Installation------------ 1) In directory "SimObjects\Airplanes" in your FSX find subdirectory "Aerosoft Twin Otter 100 Floats" 2) Copy there directory "texture.8Q-MAL" from this archive 3) Open file "aircraft.cfg" which is in directory "Aerosoft Twin Otter 100 Floats" 4) Paste there following text on place above section [General] [FLTSIM.X] title=de Havilland Canadian Twin Otter Maldivian Air Taxi (8Q-MAL) sim=DHC6 model=float panel= sound= texture=8Q-MAL kb_checklists=dhc6-300-wheel_check kb_reference=dhc6-300-wheel_ref atc_id=8Q-MAL atc_airline=MALDIVIAN atc_flight_number=003 atc_parking_types=RAMP atc_parking_code=MAT ui_manufacturer="de Havilland Canada" ui_type="DHC-6-Float" ui_variation="Maldivian Air Taxi - (8Q-MAL)" ui_typerole="Twin Engine TurboProp" ui_createdby="Aerosoft" description="Repaint of MALDIVIAN AIR TAXI by Holgi.\n \nMaldivian Air Taxi is an air taxi service based in Malé in the Maldives. It operates float-equipped Twin Otters on tourist charters throughout the Maldives. Its main base is Malé International Airport.\nThe airline was established in 1993 by Danish investors and started operations in the same year. It is wholly owned by Lars Erik Nielsen (Chairman) and has 275 employees (at March 2007)." 5) Replace X in [fltsim.X] on beginning of pasted text with number x+1, where x is maximum value in [fltsim.x] in your aircraft.cfg Das hier ist die ganze readme. Könnte mir vielleicht jemand den letzten Punkt erklären? Was ich da in der aircraft.cfg ändern muss? Gruss, Robin Zitieren
LH453 Geschrieben 25. Dezember 2009 Geschrieben 25. Dezember 2009 Du musst [FLTSIM.X]title=de Havilland Canadian Twin Otter Maldivian Air Taxi (8Q-MAL) sim=DHC6 model=float panel= sound= texture=8Q-MAL kb_checklists=dhc6-300-wheel_check kb_reference=dhc6-300-wheel_ref atc_id=8Q-MAL atc_airline=MALDIVIAN atc_flight_number=003 atc_parking_types=RAMP atc_parking_code=MAT ui_manufacturer="de Havilland Canada" ui_type="DHC-6-Float" ui_variation="Maldivian Air Taxi - (8Q-MAL)" ui_typerole="Twin Engine TurboProp" ui_createdby="Aerosoft" description="Repaint of MALDIVIAN AIR TAXI by Holgi.\n \nMaldivian Air Taxi is an air taxi service based in Malé in the Maldives. It operates float-equipped Twin Otters on tourist charters throughout the Maldives. Its main base is Malé International Airport.\nThe airline was established in 1993 by Danish investors and started operations in the same year. It is wholly owned by Lars Erik Nielsen (Chairman) and has 275 employees (at March 2007)." in die aircraft.cfg der Twin Otter einfügen. Dort wirst du andere [Fltsim.X] erkennen, jedoch mit einer laufenden Nummer anstatt dem X. Beim dem neuen Eintrag tippst du dan einfach die nächste Nummer ein. Zitieren
Robin14 Geschrieben 25. Dezember 2009 Autor Geschrieben 25. Dezember 2009 Vielen Dank für die rasche Antwort, Daniel. Ich wäre sonst nie drauf gekommen.:008: Gruss, Robin Zitieren
