Oldfly1 Geschrieben 28. Juni 2009 Geschrieben 28. Juni 2009 Moin, In Holland plant man an einem Airport in der Nordsee, und das sogar mit drehbaren Runways. Dutch plans for floating airport in North Sea 23 September, 2008 Royal Haskoning unveils airport 20km off Dutch coast, including rotating runways Dutch engineer Royal Haskoning has unveiled proposals for floating airport in the North Sea. The airport, which would sit about 20km off the Dutch coast, would include floating and rotating runways and passengers would be transferred to the mainland on shuttles through bored tunnels. Royal Haskoning, which has been working with dredging company Van Oord on the proposal, said the scheme would reduce the pressure on Schiphol Airport and cut noise and air pollution affecting local communities. The proposal also includes plans to create 250 km² of “new land” off the coast of Holland. The project would take about 25 years and use up around 3.8bn cubic metres of sand from the North Sea. The companies have also suggested a new row of dunes on the reclaimed land to cope with the expected rise in sea levels of 60-80 cm before the end of the century. The news comes as mayor of London Boris Johnson revealed plans to replace Heathrow with a 24-hour airport in the Thames estuary. >Hier ein Video darüber< Den Artikel dazu.... :) http://www.building.co.uk/story.asp?storycode=3123252 Gruß Zitieren
Johan "Bigfoot" Geschrieben 29. Juni 2009 Geschrieben 29. Juni 2009 Hallo Oldfly1 Zuerst sehen und dann glauben. :005: Das sagen die Hollander immer, aber danke für deine interessante Beitrag. Grusse von EHAM Bigfoot. :cool: Zitieren
Flying-Andy Geschrieben 30. Juni 2009 Geschrieben 30. Juni 2009 :007: Also im Flugsimulator ist das schon realisierbar, ein verregneter Sonntag mit einem Scenery Designer Progi und der Flugplatz sollte eigentlich dann "eröffnet" werden können, sogar "for free", ohne Steurgelder. :005: Beste Grüsse nach Holland Andy :D Zitieren
