Ohmaney1987 Geschrieben 10. November 2008 Geschrieben 10. November 2008 Moin, The US and UK divisions of IVAO are proud to present another collaborative event, like no other before! On the night of the 22nd November 2008, you, as a pilot, will have another chance to cross the pond, except this time, hopping Eastbound and flying overnight! Full ATC will be provided from the departure from Washington (KIAD) to the arrival in London Heathrow (EGLL) the following morning, including full oceanic control, to simulate what happens in real life, every night. The departure window from Washington is 2100z – 2230z pilots can expect full ATC at Washington during this period. The approximate flight time to Heathrow is 8hrs which means that at the latest, you will arrive into London at 0630-0700z (assuming you depart within the departure window). For further details, please visit the Event Webpage http://ivao.co.uk/events/index.php?page=details&id=104 Grab a real life flight plan that will be used by pilots on the same night, and enjoy flying as real as it gets! This is definitely not an event to be missed - see you there! Tom Perry GB-EC Ross McLennan GB-EAC Das wird def. ein Highlight! http://ivao.co.uk/events/index.php?page=details&id=104 Zitieren
FO_DAIHQ Geschrieben 21. November 2008 Geschrieben 21. November 2008 Hi, hab mal ne Frage: Bei den Pilot information auf der Eventseite steht was von OCMS. Wo kann ich das herkriegen? Danke + Ciao Zitieren
CitationCJ Geschrieben 21. November 2008 Geschrieben 21. November 2008 Hi, hab mal ne Frage: Bei den Pilot information auf der Eventseite steht was von OCMS. Wo kann ich das herkriegen? Danke + Ciao Ciao Flo, meinst du das? http://occ.ivao.ca/booking/index.php Zitieren
FO_DAIHQ Geschrieben 22. November 2008 Geschrieben 22. November 2008 Jo, genau das... Konnte bei Google und auf der Seite keine Infos finden, wo ich das herkriege.. Ciao Zitieren
Ohmaney1987 Geschrieben 22. November 2008 Autor Geschrieben 22. November 2008 Nabend nochmal, soeben wurden die Routen für heute Abend (IAD-LHR) hochgeladen. Zu finden sind sie auf der Webpage -> http://ivao.co.uk/events/index.php?page=details&id=104&pid=1 Es gibt (wie immer) zwei Routings. Das erste Routing ist über Track V, welcher für ETOPS Aircraft gedacht ist. Das zweite Routing ist über den Track W geplant und ist für Flieger wie eine B747-400 oder ein A340 gedacht. Dazu gibt es auch , wie oben schon mal angekündigt, FMC Files für die wichtigstens Addons: V-Track files PMDG -> http://ivao.co.uk/training/files/FMC/PMDG/IAD-LHR1.rte PSS -> http://ivao.co.uk/training/files/FMC/PSS/IAD-LHR1.b2r Wilco -> http://ivao.co.uk/training/files/FMC/Wilco/IAD-LHR1.rte Level D - > http://ivao.co.uk/training/files/FMC/LevelD/IAD-LHR1.rte W-track files PMDG -> http://ivao.co.uk/training/files/FMC/PMDG/IAD-LHR2.rte PSS -> http://ivao.co.uk/training/files/FMC/PSS/IAD-LHR2.b2r Wilco -> http://ivao.co.uk/training/files/FMC/Wilco/IAD-LHR2.rte Level D - > http://ivao.co.uk/training/files/FMC/LevelD/IAD-LHR2.rte Bitte mit der rechten Maustauste abspeichern! Zitieren
Ohmaney1987 Geschrieben 23. November 2008 Autor Geschrieben 23. November 2008 Danke nochmal an euch Alle gestern. Ihr habt einen Super Job gemaacht. Normalerweise schreib ich ja immer viel zu solchen Events, aber diesmal ist denke ich weniger mehr. Ich hoffe man sieht sich beim nächsten mal auch wieder:) Zitieren
