Apron
Habe in der Suchmachine nicht gefunden was "Apron" heisst...
Danke und si ju Para
Quelle: http://www.flightsim.ch/index.htm
APRON- A defined area on an airport or heliport intended to accommodate aircraft for purposes of loading or unloading passengers or cargo, refueling, parking, or maintenance. With regard to seaplanes, a ramp is used for access to the apron from the water.
(See ICAO term APRON.)
APRON [iCAO]- A defined area, on a land aerodrome, intended to accommodate aircraft for purposes of loading or unloading passengers, mail or cargo, refueling, parking or maintenance.
grüsse - brünu
Hallo Werner
Zu deutsch heisst das "Vorfeld", und ein anderes fremdsprachiges Wort dafür ist "Tarmac".
Gruss Markus
Redaktion Glide Slope, Vereinszeitschrift des ILS - glideslope@airliners.ch
Hallo Brünu und Markus
Danke!
si ju Para
