Allgemein NEU! WoAI Für KaiTak
für alle Freunde des KaiTak Airports
File Description:
So lonely at Kai Tak? No problem. If you install these Flightplans, you can 'reopen' the old Hong Kong Kai Tak airport with some Cathay B747-400RR and Cathay A330-300RR aircraft. (These flight plans are not real in the 21th century.) I'm about to make other airlines' access to Kai Tak to reopen the airport. You will find them when they will be ready! Install using TTools. You will need the WOAINS24.zip and this package: http://library.avsim.net/download.php?DLID=126088
Bitte beachten, daß es sich hierbei nicht um ein offizielles WOA release handelt. Hierfür übernehmen wir keine Verantwortung und/oder Support.
