VATSIM Squawkbox 4 - es ist bald soweit!
Liebe Freunde des gepflegten Onlineflugs,
wie in den letzten Tagen zu lesen war, wurde die neue Version 4 der Pilotensoftware Squawkbox an VATSIM geschickt, um dort auf Konformität mit den Software-Regularien des Netzwerks überprüft zu werden:
August 11, 2008
SB4 Build Sent to VATSIM
The candidate build we believe is ready for a public beta release has been sent to VATSIM. I don't have visibility on when they will approve it for release, but I believe it will be sometime next week.
Thank you all who have waited so patiently for this release. And thanks again to Brian for playing a key role in getting the code finished.
See you in the skies....
Das Statement des VATSIM-Staff dazu lautete gestern:
SB4 has been received by VATSIM for approval. We expect to release it as an open beta for use on the VATSIM network sometime (most likely the end of) next week. Please don't start flooding the forums with requests of "when will it happen" on Monday. It will be reviewed and approved as quickly as possible. If we encounter a hiccup that will delay release, a member of the BoG will post an announcement in these forums.
Also, es ist nicht mehr lange, bis ihr mit dem FSX die Squawkbox nutzen könnt!
Stefan Friedrich
Hallo Zusammen
Die Squawkbox 4 wurde releast.
Zu downloaden gibt es sie hier: http://www.squawkbox.ca
Viel Spass!
Grüsse
Stefan
