Problem Installation liveries
Ich habe mir die Flightcraft A330 mit dazu passenden Liveries runtergeladen, alles
nach ReadMe installiert. Leider ist mir irgendwo ein Fehler unterlaufen, da die
Flugzeuge nur Blank angezeigt werden.
Unten die ensprechende Aircraft.cfg. Wo ist der Fehler versteckt? Habs bis jetzt nicht selber rausgefunden:confused:
[fltsim.0]
title=Flightcraft Airbus A330-200 Corsair
sim=FCA332_RR_2
model=rr
panel=
sound=
texture=corsair
kb_checklists=
kb_reference=
atc_id=HCAT
atc_id_color=0xffffffff
atc_airline=Corsair
atc_flight_number=0002
ui_manufacturer=FlightCraft
ui_type=A330-200
ui_variation=Corsair-RR
description=The A330 family has established itself as one of the most advanced, comfortable and reliable long-haul passenger and cargo airplane. The cockpit has long been looked upon as the most avanced alongside the Triple Seven. \n\nTeam Memebers who Made This Possible: \n*GMAX Modelling Glaeson Ramnarine\n*Virtual Cockpit Peter Skolte \n*2D Cockpit Eric Marciano \n*Flight Model Eugene Shneyder\n*Artwork: \n*Copyright 2003 FlightCraft
atc_heavy=0
[fltsim.1]
title=Flightcraft A330-200 Monarch NC
sim=FCA332_RR_2
model=rr
panel=
sound=
texture=monarch-nc
kb_checklists=
kb_reference=
atc_id=G-SMAN
atc_airline=Monarch
atc_flight_number=5342
ui_type=A330-200
ui_variation=Monarch NC
atc_heavy=0
[fltsim.2]
title=Air Transat New Colors
sim=FCA332_RR_2
model=rr
panel=
sound=
texture=Air Transat NC
kb_checklists=
kb_reference=
atc_id=C-GITS
atc_airline=FLIGHTCRAFT
ui_type=A330-200
ui_variation=Air Transat NC
atc_heavy=0
[fltsim.3]
title=Airbus HC NC
sim=FCA332_RR_2
model=rr
panel=
sound=
texture=airbusnc
kb_checklists=
kb_reference=
atc_id=NTEJ
ui_type=A330-200
ui_variation=Airbus House NC-RR
atc_heavy=0
[fltsim.4]
title=Emirates
sim=FCA332_RR_2
model=rr
panel=
sound=
texture=emirates
kb_checklists=
kb_reference=
atc_id=NTEJ
ui_type=A330-200
ui_variation=Emirates-RR
atc_heavy=0
[fltsim.5]
title=Gulf
sim=FCA332_RR_2
model=rr
panel=
sound=
texture=gulf
kb_checklists=
kb_reference=
atc_id=NTEJ
ui_type=A330-200
ui_variation=Gulf NC-RR
atc_heavy=0
[pitot_static]
vertical_speed_time_constant = 999
[weight_and_balance]
// Use this to adjust the loading of the aircraft
// Be ware of CoG position !!!
max_gross_weight = 515660
empty_weight = 265160
reference_datum_position = 0, 0, 0
empty_weight_CG_position = -2.6, 0, 0
empty_weight_pitch_MOI = 15357021
empty_weight_roll_MOI = 7636327
empty_weight_yaw_MOI = 17329467
empty_weight_coupled_MOI = 0
max_number_of_stations = 7
station_load.0 = 450, 0.0, 0.0, 0.0 //Weight Crew (lbs) LEAVE
station_load.1 = 3000, 0.0, 0.0, 0.0 //Weight Galleys (lbs) LEAVE
station_load.2 = 36826, 0.0, 0.0, 0.0 //Weight Baggage (lbs)
station_load.3 = 16944, 0.0, 0.0, 0.0 //Weight Cargo (lbs)
station_load.4 = 1800, 0.0, 0.0, 0.0 //Weight First Class (lbs)
station_load.5 = 5400, 0.0, 0.0, 0.0 //Weight Business Class (lbs)
station_load.6 = 24300, 0.0, 0.0, 0.0 //Weight Economy Class (lbs)
[lights]
//Types: 1=beacon, 2=strobe, 3=navigation, 4=cockpit, 5=landing
light.0 = 2, -28.34, -96.073, 10.6, fx_FC_Strobe,
light.1 = 3, -95.98, 0, 11.88, fx_navwhi
light.2 = 2, -28.34, 96.073, 10.6, fx_FC_Strobe
light.3 = 1, 20.68, 0, -4.72, fx_FC_beacon
light.4 = 1, 13.99, 0, 14.7, fx_FC_beacon
model=rr verlangt auch Texturen für RR-Model.
Stimmen Texturen und Model (RR-Triebwerk) überein?
Evtl. mußt Du das PW (??) Model nehmen?
Hi Stefan ,
Also ich kann da jetzt keinen Fehler endecken,check doch bitte mal die dazugehörigen texture Ordner,ob diese den korrekten Namen haben,muß also zB " texture.monarch-nc " lauten, der Punkt nach dem " texture" ist ganz wichtig ! !,danach darf auch kein Leerzeichen sein,"monarch-nc " muß auch genauso geschrieben sein wie in der cfg. ! Groß und Kleinschreibung beachten !
Sind alle Repaints davon betroffen,oder werden nur einzelene Blank dargestellt ?
Gruß,Thomas:)
Tatsächlich hing das Problem mit den texture-Ordnern zusammen. Die Ordner waren
in einem übergeordneten Ordner enthalten.
Dank Euren Tipps funktionieren jetzt die Hälfte der Liveries. Nur die Emirates- und
Gulf-Livery funktionieren noch nicht.
