Neue Mirage IIIS Repaints
Johan "Bigfoot"
Hallo Mirage III Freunden.
Nein diese Repaints sind nicht von der Mirage III von Bambini Uno aber eine neue Freeware Mirage III.
Die beide Repaints File's habe ich bei Sim-Outhouse gefunden.
Diese drei registrierungen gibt es: 2102, 2117 und nochmal 2117.
Die beide Repaint File's brauche diese File (miiiebr2.zip) fur das model.
FS9MIrage_IIIS_SwissAF.zip und
Mirage_IIIE_Swiss_photoreal_FS9.zip
Gruss Bigfoot. :cool:
Photo-real texture for the FS2004 Dassault/Breguet Mirage IIIE
by J.E. Narcizo. Available at flightsim.com, filename miiiebr2.zip.
Not hystorical accurate,most likely this camo liveries were used on a MirageIII RS by the Swiss Air Force.
ATTN, this textures were made for a MODIFIED model with the shine removed via MDLC or MDLMat...Add this textures
on the default model and will look like crap.. I attached a shot of the value you need to set your MDLC for best results.
Hier mal ein par Screenshots.
