EDDK Geschrieben 11. September 2007 Geschrieben 11. September 2007 Hallo Simmer, EvolveAI hat den A300B2-B4 releast. Wer in der letzten Zeit die Seite von EvolveAI besuchte konnte sich auf der Titelseite schon von der neuen Qualität des Airbus überzeugen. Damit verlassen wieder einmal die Modelle von FSP die Flotten von vielen AI-Simmern. Für die, die des Englischen mächtig sind: "The FSPainter A300B4 has served the AI Community well, but it has been in service a long time, and the art of creating AI models has moved forward since the FSP model was released. Therefore, our intent has been to replace the FSP model, and raise the bar in a number of different ways. Compared to the FSPainter A300B4 (or the PAI equivalent), this EvolveAI A300B2-B4 model offers: a) Lower polygon count at LOD1 of 3,419 compared to 4,424. b) Ten LODs compared to only five for the FSPainter. c) One main 1024x1024 texture and one 512x512 lights texture compared to four textures. The EvAI A300B2-B4 has combined textures of 1,280 KB, while the FSP has as many as 2,560 KB. d) These three key differences offer the potential of better frame rate performance, depending on the resources available in the user’s system. e) The EvolveAI model also has all of the animations of more recent AI models such as takeoff flaps. Although additional XML coding tends to reduce framerate performance, the EvAI A300 offers a net gain that may be considerable on some systems. f) Our model is more accurate than the FSP in some very significant and noticable ways and matches the accuracy of the best AI models." Derzeit werden auf avsim.com schon viele repaints hochgeladen. Zitieren
Ömer Geschrieben 11. September 2007 Geschrieben 11. September 2007 Derzeit werden auf avsim.com schon viele repaints hochgeladen. Diese werden gleich gedownloaded ;) danke für die Info ! Zitieren
B787 Geschrieben 11. September 2007 Geschrieben 11. September 2007 Jetzt kommt das grosse Ersetzen! ;) Danke für den Tipp! Zitieren
cameron Geschrieben 12. September 2007 Geschrieben 12. September 2007 Das grosse ersetzen kann leider noch nicht beginnen,weil es noch nicht sehr viele Liverys dazu gibt....aber klar sind diese Modelle einiges besser und schöner als die alten FSP Hat eigentlich jemand die neue Boeing 767-200 gezogen von AI Malcontent ai_malcontent_boeing_767-200.zip gezogen? Das Teil habe ich mir installiert aber die Delta Air Lines bekomme ich nicht hin zum anzeigen bzw. laden. Zitieren
