Brauche eure Hilfe Betreff Emirates Flugplan
Hallo Zusammen,
Ich brauche eure Hilfe denn bei mir Fliegt die Emirates A340-500 ab Zürich immer eine Stunde früher ab Statt geplant 14:40 Uhr geht sie schon um die ca.13:40 Uhr.
Aber das ist nur beim Nachmittags Flüge die Abend Flüge geht die Emirates A330 Planmäßig raus.
Hier der Flugplan des A340-500 der Emirates:
AC#4152,A6-ERA,92%,WEEK,IFR,0/13:59:11,@1/02:08:51,380,F,0315,OMDB,1/04:41:26,@1/10:32:07,360,F,0087,LSZH,1/12:38:51,@1/19:35:59,370,F,0088,OMDB,1/22:49:10,@2/07:39:30,350,F,0316,RJBB,2/14:13:15,@3/02:02:00,340,F,0317,OMDB,3/04:44:25,@3/10:30:11,360,F,0087,LSZH,3/12:39:23,@3/19:38:58,370,F,0088,OMDB,3/22:44:46,@4/07:49:52,370,F,0314,RJNN,4/13:56:33,@5/02:06:13,380,F,0315,OMDB,5/04:28:57,@5/18:05:59,320,F,0201,KJFK,6/03:00:00,@6/16:32:07,330,F,0202,OMDB,6/22:43:43,@0/07:48:49,370,F,0314,RJNN
AC#4152,A6-ERB,50%,WEEK,IFR,0/14:13:57,@1/02:03:56,340,F,0317,OMDB,1/04:26:40,@1/18:09:51,320,F,0201,KJFK,2/02:58:57,@2/16:34:45,330,F,0202,OMDB,4/04:44:04,@4/10:34:45,340,F,0087,LSZH,4/12:37:48,@4/19:39:51,370,F,0088,OMDB,4/22:46:53,@5/07:35:59,330,F,0316,RJBB,5/14:14:39,@6/02:04:38,340,F,0317,OMDB,6/04:43:22,@6/10:34:03,360,F,0087,LSZH,6/12:35:52,@6/19:37:55,370,F,0088,OMDB,6/22:49:52,@0/07:38:58,330,F,0316,RJBB
AC#4152,A6-ERC,11%,WEEK,IFR,0/05:59:18,@0/20:53:51,330,F,0412,YSSY,0/22:28:36,@1/01:28:15,390,F,0412,NZCH,1/06:43:15,@1/10:03:49,380,F,0413,YSSY,1/11:43:29,@2/01:26:40,320,F,0413,OMDB,2/04:30:00,@2/18:09:30,320,F,0201,KJFK,3/02:58:36,@3/16:34:24,330,F,0202,OMDB,3/22:47:14,@4/07:37:34,350,F,0316,RJBB,4/14:15:00,@5/02:04:59,340,F,0317,OMDB,5/06:00:00,@5/20:50:52,330,F,0412,YSSY,5/22:29:18,@6/01:28:57,370,F,0412,NZCH,6/06:43:57,@6/10:04:31,360,F,0413,YSSY,6/11:44:11,@0/01:28:36,320,F,0413,OMDB
AC#4152,A6-ERJ,30%,WEEK,IFR,0/22:49:31,@1/07:39:51,330,F,0316,RJBB,1/14:13:36,@2/02:02:21,340,F,0317,OMDB,2/22:48:49,@3/07:37:55,350,F,0316,RJBB,3/14:11:40,@4/02:00:25,340,F,0317,OMDB,4/04:29:18,@4/18:07:34,320,F,0201,KJFK,5/02:56:40,@5/16:32:28,330,F,0202,OMDB,5/22:45:18,@6/07:39:19,350,F,0316,RJBB,6/14:14:18,@0/02:04:17,340,F,0317,OMDB
AC#4152,A6-ERH,94%,WEEK,IFR,0/04:41:47,@0/10:32:28,360,F,0087,LSZH,0/12:39:12,@0/19:37:34,370,F,0088,OMDB,1/05:58:57,@1/20:54:44,330,F,0412,YSSY,1/22:28:15,@2/01:26:40,390,F,0412,NZCH,2/06:41:40,@2/10:02:14,380,F,0413,YSSY,2/11:43:08,@3/01:30:00,320,F,0413,OMDB,3/05:58:15,@3/20:52:48,330,F,0412,YSSY,3/22:30:00,@4/01:29:39,370,F,0412,NZCH,4/06:44:39,@4/10:00:18,380,F,0413,YSSY,4/11:44:53,@5/01:29:18,320,F,0413,OMDB,5/04:43:43,@5/10:34:24,340,F,0087,LSZH,5/12:36:13,@5/19:39:30,370,F,0088,OMDB
AC#4152,A6-ERG,72%,WEEK,IFR,0/02:59:39,@0/16:30:32,330,F,0202,OMDB,0/22:43:22,@1/07:47:14,330,F,0314,RJNN,1/13:58:50,@2/02:09:44,340,F,0315,OMDB,2/05:58:36,@2/20:54:23,330,F,0412,YSSY,2/22:26:40,@3/01:30:00,390,F,0412,NZCH,3/06:45:00,@3/10:01:53,360,F,0413,YSSY,3/11:41:33,@4/01:29:39,320,F,0413,OMDB,4/05:56:40,@4/20:51:13,330,F,0412,YSSY,4/22:29:39,@5/01:29:18,390,F,0412,NZCH,5/06:44:18,@5/10:04:52,360,F,0413,YSSY,5/11:44:32,@6/01:28:57,320,F,0413,OMDB,6/04:28:36,@6/18:09:19,320,F,0201,KJFK
AC#4152,A6-ERF,86%,WEEK,IFR,0/06:43:36,@0/10:04:10,360,F,0413,YSSY,0/11:43:50,@1/01:28:15,320,F,0413,OMDB,1/06:07:34,@1/20:33:49,330,F,0406,YMML,1/22:06:06,@2/01:38:58,370,F,0406,NZAA,2/06:49:03,@2/10:45:18,380,F,0407,YMML,2/12:24:58,@3/01:39:51,320,F,0407,OMDB,3/04:29:39,@3/18:07:55,320,F,0201,KJFK,4/02:58:15,@4/16:34:03,330,F,0202,OMDB,4/22:44:25,@5/07:49:31,330,F,0314,RJNN,5/13:59:53,@6/02:05:52,340,F,0315,OMDB,6/05:59:39,@6/20:54:12,330,F,0412,YSSY,6/22:28:57,@0/01:28:36,390,F,0412,NZCH
AC#4152,A6-ERI,2%,WEEK,IFR,0/06:49:45,@0/10:47:14,380,F,0407,YMML,0/12:20:45,@1/01:39:19,320,F,0407,OMDB,1/02:59:18,@1/14:43:08,350,F,0306,ZBAA,1/23:29:46,@2/04:47:14,340,F,0307,OMDB,2/06:05:59,@2/20:32:14,330,F,0406,YMML,2/22:05:45,@3/01:39:51,370,F,0406,NZAA,3/06:47:28,@3/10:49:52,380,F,0407,YMML,3/12:24:37,@4/01:39:30,320,F,0407,OMDB,4/06:08:58,@4/20:30:18,330,F,0406,YMML,4/22:09:58,@5/01:37:55,390,F,0406,NZAA,5/06:45:32,@5/10:49:10,380,F,0407,YMML,5/12:22:41,@6/01:37:34,320,F,0407,OMDB,6/06:09:30,@6/20:34:31,330,F,0406,YMML,6/22:08:02,@0/01:35:59,390,F,0406,NZAA
AC#4152,A6-ERE,5%,WEEK,IFR,0/04:28:15,@0/18:08:58,320,F,0201,KJFK,1/02:59:18,@1/16:30:11,330,F,0202,OMDB,1/22:41:47,@2/07:46:53,330,F,0314,RJNN,2/13:58:29,@3/02:09:23,340,F,0315,OMDB,3/06:09:19,@3/20:31:53,330,F,0406,YMML,3/22:09:05,@4/01:39:30,370,F,0406,NZAA,4/06:47:07,@4/10:49:31,380,F,0407,YMML,4/12:23:02,@5/01:37:55,320,F,0407,OMDB,5/06:09:51,@5/20:34:52,330,F,0406,YMML,5/22:09:37,@6/01:37:34,390,F,0406,NZAA,6/06:45:11,@6/10:48:49,360,F,0407,YMML,6/12:21:06,@0/01:35:59,320,F,0407,OMDB
AC#4152,A6-ERD,4%,WEEK,IFR,0/06:07:55,@0/20:34:10,330,F,0406,YMML,0/22:07:41,@1/01:39:19,390,F,0406,NZAA,1/06:49:24,@1/10:46:53,360,F,0407,YMML,1/12:24:05,@2/01:38:58,320,F,0407,OMDB,2/04:44:46,@2/10:30:32,360,F,0087,LSZH,2/12:39:44,@2/19:39:19,370,F,0088,OMDB,2/22:41:26,@3/07:45:18,330,F,0314,RJNN,3/13:58:08,@4/02:07:48,340,F,0315,OMDB,5/22:44:04,@6/07:49:10,330,F,0314,RJNN,6/13:59:32,@0/02:09:12,340,F,0315,OMDB
Für eure Hilfe bin ich sehr dankbar.:)
MfG,
Marcel
hallo marcel,
also laut deinem flightPlan stimmt das so auch ,
Mo +Mi ca.12.40 entspricht 13.40 gmt
Do+Samst. ca 12.40 entspricht 13.40gmt
Sonnnt.+Freitag ca.12.40 entspricht 13.40gmt
wenn du das selbst ändern möchtest, kannst du mit AITM von th.molitor den flightplan auf alle abflüge vormittags um ca.11.40 vorverlegen und dann nochmals kompilieren.
vg
joerg
Hallo Joerg,
Gibt es eine Deutsche Anleitung wie mann das AITM Installiert?:confused:
MfG,
Marcel
So eine kleine Änderung kann man problemlos von Hand machen. Du willst, dass sie täglich um 14:40 (lokal) abfliegt, richtig?
Such alle Einträge (sieben Stück) LSZH. Der erste Eintrag lautet so: ...LSZH,1/12:38:51...
Du änderst 12:38 in 13:38 und schon ist es erledigt. Bei den sechs verbleibenen LSZH Einträgen das gleiche und schon fliegen sie pünktlich.
PS: Dein Problem erfolgt übrigens wegen der Sommerzeit entstanden. 12:40z ist im Sommer 14:40 lokal, im Winter aber 13:40.
Hallo Michael,
Also ja ich will das die Emirates um die 14:40 Schweizer zeit Abfliegt sonst wäre es nicht Real wenn du verstehst.;)
Also die Emirates Flugplan ist für den Winter 2006/2007 gemacht.
Kann mann das auch für die Landung was machen da kommt die auch Früher als in echt in Echt kommt die Emirates A340-500 so um die 12:35 Uhr Schweizer zeit.
MfG,
Marcel
Das funktioniert so: Wieder die LSZH Einträge suchen, jetzt gehts aber um die Uhrzeit vor "LSZH". Ich erkläre es wieder am Beispiel des ersten Eintrages:
...@1/10:32:07,360,F,0087,LSZH,1/13:38:51
Diese Uhrzeit stellst du von 10:32 (z) auf 11:32 und schon landet sie um 12:32 lokal.
(Die hintere fette 3 gilt, wenn du den oberen ersten Schritt schon gemacht hast.)
Hallo Michael,
Ich möchte dir ganz herzlichst bedanke für deine Hilfe.:) Ich werde grad mall die Änderungen im Flugplan vornehmen.:):008:
MfG,
Marcel
hallo marcel,hallo michael,
michael ,du hast natürlich recht,er (marcel) kann es auch händisch machen.also ohne AITM .
marcel: AITM gibt's auf der hp von thomas molitor hier der link ,alles in deutsch:
http://www.molitor-home.de/FS/AITM/
das problem dabei ist, dass beim kompilieren mit TTool's die zeiten geringfügig verändert werden .deshalb habe ich diese art der änderung zunächst nicht empfehlen wollen.dies passiert dann,weil du ja nicht alle zeiten änderst.wodurch sich die standzeiten verändern werden auf allen anderen plätzen.
aber sicher ist, man kann es so auch machen,nur bitte,danach sofort zur überprüfung zurückkompilieren um nachzuschauen ob alles wie gewollt funktioniert.
vg
joerg
