Fsuipc 3.7.
MajorFibbs
Hallo Flusianer
Gestern bin ich über eine Info gestolpert dass die aktuelle FSUIPC Version 3.7. ist. Und siehe da, tatsächlich.
Mehr auf www.schiratti.com
Version 3.70 (July 2006)
  • The ShortAircraftNameOk parameter can now be set to ‘Substring’ to make FSUIPC accept aircraft names with the INI file aircraft name included as a sub-string anywhere within the full name. This gives more flexibility in applying aircraft-specific assignments, and applies to all sections using the facility (i.e. Axes, Calibrations, Buttons, and Keys).
  • Additional offsets are provided for water rudder data from FS:
    - 2A78 water left rudder position (double)
    - 2A80 water right rudder position (double)
    - 2A88 water rudder handle position (32-bit BOOL)
  • An error is fixed in the Buttons and Keys assignment facilities. This could have disabled the final button or key assignment left when the penultimate one is deleted.
  • Bit 2^4 (value 16) in offset 330C is set when the FSUIPC Hot Key for throttle synchronisation is used and the sync engages.
