Trini_Tom Geschrieben 28. Februar 2006 Geschrieben 28. Februar 2006 Hey! Wie es oben steht hat CLS ihren A340-600 gestern released, bis jetzt hat sich hier keine regung dazu getan deshalb dieser post.... Price: € 23,95 Bilder finded ihr hier: http://www.commerciallevel.com/pictures/a340600/ Und ein kleiner auszug aus der Liste der langen.... Model Features - Highly realistic exterior model - Full virtual Cockpit - Wingviews - 3D pushback truck - Tires stay flat on ground while takeoff or landing - Dynamic shine - Dynamic wingflex (with bouncing of turbulence) ----------------------------------------------- ----------------------------------------------- Paint features - Realistic paint work - Layered Paint kit - CLS house livery - 9 additional airline liveries for free - Open repaint policy ----------------------------------------------- ----------------------------------------------- FDE Features Highly tuned A340-600 FDE based on highly detailed Airbus documentation and experience in Airbus full motion, 6-axis simulators. - CLS "True Feel" correct performance and feel based on FAA Level D simulators. - Use of the default MSFS payload and fuel editor. - Use of default MSFS flight planner and Navigation Log for accurate flight/fuel planning. - Use of true A340-600 landing gear footprint as default gear points. - More than 60 individual contact point definitions and damage profiles throughout the aircraft - More than 15 individualize effects attached to the physical properties of the aircraft - Soundset recorded from actual A340 models with Rolls Royce Trent 500s - CLS / A346 Flight Operations Manual with full flight procedures - Full CLS / A346 Checklist - Full CLS / A346 Reference Charts ----------------------------------------------- ----------------------------------------------- 2D panel features - All New A340-600 panel with realistic gauges - Overhead panel comes complete with packs, fire, fuel dump, apu, and lighting controls - Realistic ND with limited waypoint display based on MSFS flight plan - Realistic EICAM displays, covering many systems such as hydraulic pressure, flight controls, electrical power and many more - Limited function FMC which allows for SIDs and STARs in the MSFS database, Radio and Navigation frequency entry, v-speed calculation, "direct to" waypoint features, progress display, estimated fuel on board, and more. - EFIS displays, complete with Contraints, VOR, NDB, waypoint and Airport overlays - Realistic PFD with limited Airbus Laws Logic and Alpha Protection ------------- Hat ihn schon wer von euch? Wie ist er? Model Cockpit? Auf den Bildern scheint alles sehr schön auszusehen... Grüsse Thomas Zitieren
Hergi Geschrieben 28. Februar 2006 Geschrieben 28. Februar 2006 Ich denke, ein Merge mit dem PSS Panel und dem Simubuild oder Flightcraft Modell kommt da wesentlich besser... Gruß Zitieren
Marcel Staubli Geschrieben 28. Februar 2006 Geschrieben 28. Februar 2006 Hallo Thomas, Danke für die Infos. PS: Wann kommt eigentlich die A340-500 von IFDG Raus? MfG, Marcel Zitieren
Tobisky Geschrieben 28. Februar 2006 Geschrieben 28. Februar 2006 Wenn ich mir die Bilder ansehe, dann weiss ich, dass ich das Produkt sicherlich nicht kaufen werde. Hergi hat es getroffen: Mit dem PSS-Panel und einem schicken Freewaremodell lässt es sich ganz gut leben Zitieren
D-AERB Geschrieben 5. März 2006 Geschrieben 5. März 2006 Wann kommt eigentlich die A340-500 von IFDG Raus?Nach dem gegenwärtigen Stand der Dinge, warscheinlich niemals. Jedoch arbeitet CLS momentan an einem A340-500. ;) Ich habe diesen Model und der Visual Model sieht verdammt gut aus. Missi, der Modeller, hat eine ausgezeichnete Arbeit gemacht, obwohl das VC-Model sehr schwere FPS-Einbußen machen kann, aber es wird gerade an eine SP1 gearbeitet, um dieses Problem u. a. zu lösen. Der Panel ist zwar nicht das feinste und die Flightdynamics vielleicht auch nicht obwohl die FDE noch gerade Anständig ist für mich, aber um das Panelproblem zu lösen braucht man nur einen PSS Merge (sobald ich den PSS-Panel habe, werde ich definitiv selbst auch den Merge verwenden). Außerdem sind die Models von Flightcraft und Simubuild ja uralt und sehen auch nicht gerade prickelnd aus. Sonst lohnt es sich, auchwenn es vielleicht ein bisschen Teuer erscheinen mag. Ich arbeite momentan sogar an einem SR und LX repaint für das Model. :p Zitieren
Marcel Staubli Geschrieben 5. März 2006 Geschrieben 5. März 2006 Hallo Richie, Danke für die Info. Wenn ich die Bilder ansehe von der A340-500 muss ich schon sagen ich freue mich schon wenn der A340-500 rauskommt.:) A340-500 CLS (Emirates) Bilder:http://www.commerciallevel.com MfG, Marcel Zitieren
