Dream Pilot Geschrieben 3. März 2001 Geschrieben 3. März 2001 Hi Leute Ich habe ein kleines Problem! Bei mir kommen im Panel die Gauges des Porters nicht also nur die Schalter welche für das Licht, Batterie, Generator, usw. benötigt werden. Die panel.cfg sieht folgendermassen aus: ------------------------------------- //PILATUS PC6 standard [Window Titles] window00=Porter window01=FS2000 GPS Fixed Window30=Forward Right Fixed Window31=Right Fixed Window32=Rear Right Fixed Window33=Rear Fixed Window34=Rear Left Fixed Window35=Left Fixed Window36=Forward Left Fixed Window37=Up [Views] VIEW_FORWARD_WINDOWS=MAIN_PANEL VIEW_FORWARD_DIR=4.50, 0.0, 0.0 VIEW_FORWARD_ZOOM=0.8 VIEW_FORWARD_RIGHT_WINDOWS=30 VIEW_FORWARD_RIGHT_DIR=4.0, 0.0, 45.0 VIEW_RIGHT_WINDOWS=31 VIEW_RIGHT_DIR=0.0, 0.0, 90.0 VIEW_REAR_RIGHT_ZOOM=0.7 VIEW_REAR_RIGHT_WINDOWS=32 VIEW_REAR_RIGHT_DIR=8.5, 0.0, 135.0 VIEW_REAR_ZOOM=0.6 VIEW_REAR_WINDOWS=33 VIEW_REAR_DIR=8.5, 0.0, 180.0 VIEW_REAR_LEFT_ZOOM=0.7 VIEW_REAR_LEFT_WINDOWS=34 VIEW_REAR_LEFT_DIR=8.5, 0.0, 200.0 VIEW_LEFT_WINDOWS=35 VIEW_LEFT_DIR=-3.0, 0.0, 270.0 VIEW_FORWARD_LEFT_WINDOWS=36 VIEW_FORWARD_LEFT_DIR=8.0, 0.0, 315.0 VIEW_UP_WINDOWS=37 VIEW_UP_DIR=-30.0, 0.0, 0.0 [Window00] file=pil.bmp size_mm= 1024 , 0 position= 6 visible=1 ident=0 gauge00=Mooney_Bravo!Whiskey Compass, 905, 224, 46, 33 gauge01=PC6_suction,145,398,64,61 gauge02=PC6_Oil, 135, 474, 95, 89 gauge03=PC6_CESSNA_182.TURN_COORDINATOR, 154, 587, 75, 66 gauge04=PC6_Airspeed,238,356,107,105 gauge05=PC6_Attitude,375,355,109,105 gauge06=PC6_Altimeter,515,357,111,103 gauge07=PC6_adf.model_a, 245,472,102,97 gauge08=Mooney_Bravo!HSI, 371, 469, 118, 102 gauge09=PC6_Climb,515,470,106,94 gauge10=Cessna!DME, 269,610,102,35 gauge11=PC6_VOR2, 383,576,101,88 gauge12=PC6_Fuel, 515,575,100,86 gauge13=PC6_Reverse_Light, 494, 456, 25, 25 gauge14=PC6_Stall_Warn,492,560,25,25 gauge15=PC6_Pitch_Warn,343,455,25,25 gauge16=PC6_clock, 153, 670, 81, 80 gauge17=Mooney_Bravo!Whiskey Compass,262,690,34,15 gauge18=PC6_ACS.GPS98-KLN90B_CRT,306, 677, 223, 68 gauge19=PC6_trim, 267, 733, 35, 13 gauge20=PC6_Prop_RPM, 697,330,81,82 gauge21=PC6_RPM, 796,330,81,82 gauge22=PC6_Torque, 686,415,90,88 gauge23=PC6_Tit, 680 ,502,89,88 gauge24=PC6_omi, 802, 421, 58, 23 gauge25=PC6_Oil_Warn,803,454 gauge26=PC6_Volts_Warn,834,454 gauge27=PC6_Boost_Pump,799,491,26,35 gauge28=PC6_Starter,831,493,35,34 gauge29=PC6_Pitot_Heat,795,537,26,45 gauge30=PC6_AntiIce,825,538,26,43 gauge31=PC6_Controls, 649, 673, 243, 83 gauge32=PC6_Master_Batt,866,600,25 gauge33=PC6_Generator,892,600,25 gauge34=PC6_Avionics,918,600,25 gauge35=PC6_Landing_Lights,944,600,25 gauge36=PC6_Nav_Lights,970,600,25 gauge37=PC6_Strobe_Lights,996,600,25 gauge38=Extra-300!GPS Display Toggle,288,716,15,15 gauge39=Mooney_Bravo!Wing Flap Display,554,676,25,74 gauge40=PC6_RADIO!Nav1,916,369,80,89 gauge41=PC6_RADIO!Nav2,912,410,80,89 gauge42=PC6_RADIO!Com1,908,455,80,89 gauge43=PC6_RADIO!xpndr,947,500,80,89 gauge44=PC6_RADIO!Adf,920,543,80,89 gauge45=PC6_ap!Bendix-King Radio AP,890,336,155,42 [Window01] windowsize_ratio=1.000 position=6 size_mm=250,410 window_pos=0.0,0.467 window_size=0.245,0.533 background_color=16,16,16 visible=0 ident=GPS_PANEL gauge00=gps!gps,0,0,250,410 [Fixed Window30] file=FORWARD_RIGHT.bmp visible=0 nomenu=1 render_3d_window=1 window_pos=0.0,0.0 window_size=1.000,1.000 ident=30 [Fixed Window31] file=RIGHT.bmp size_mm= 1024 , 0 visible=0 render_3d_window=1 window_pos=0.0,0.0 window_size=1.000,1.000 ident=31 gauge00=PC6_oat,691,151,87 [Fixed Window32] file=REAR_RIGHT.bmp visible=0 nomenu=1 render_3d_window=1 window_pos=0.0,0.0 window_size=1.000,1.000 ident=32 [Fixed Window33] file=REAR.bmp visible=0 nomenu=1 render_3d_window=1 window_pos=0.0,0.0 window_size=1.000,1.000 ident=33 [Fixed Window34] file=REAR_LEFT.bmp visible=0 nomenu=1 render_3d_window=1 window_pos=0.0,0.0 window_size=1.000,1.000 ident=34 [Fixed Window35] file=LEFT.bmp visible=0 nomenu=1 render_3d_window=1 window_pos=0.0,0.0 window_size=1.000,1.000 ident=35 [Fixed Window36] file=FORWARD_LEFT.bmp visible=0 nomenu=1 render_3d_window=1 window_pos=0.0,0.0 window_size=1.000,1.000 ident=36 [Fixed Window37] file=UP.bmp visible=0 nomenu=1 render_3d_window=1 window_pos=0.0,0.0 window_size=1.000,1.000 ident=37 [8 Bit Colors] [Default View] X=0 Y=0 SIZE_X=8191 SIZE_Y=3000 ------------------------------------- Ich habe schon nachgeschaut ob die Gauges enthalten sind und das sind sie auch! Ich habe den Porter schon mehrmals deinstalliert und wieder installiert. Das hat auch nichts gebracht! Jetzt bleibt nur noch ihr übrig... Der verzwifelte Oliver *heuljetztkannichnichtporterfliegen* ------------------ Meine Homepage jetzt mit FORUM (es werden noch Moderatoren gesucht)!!: Oliver's Flusi Site Zitieren
FrancoW Geschrieben 3. März 2001 Geschrieben 3. März 2001 Hallo Oliver, Eine wahrscheinlich dumme Antwort, trotzdem: a) Beim Starten ist das Cockpit „kalt“, d.h. Gauges werden erst angezeigt, wenn Batterie/Generator gestartet wurde. b) Wichtig: - Installation nur mit FSPCT601.EXE - Directory FS2000 - nicht FS2000\AIRCRAFT. Gruss Franco [Dieser Beitrag wurde von FrancoW am 03. März 2001 editiert.] Zitieren
Dream Pilot Geschrieben 3. März 2001 Autor Geschrieben 3. März 2001 Danke für deine Hypermegamultischnelle Antwort! Aber unterdessen konnte ich mir schon selbst helfen. Ich habe den Fs neuinstalliert. Und jedes Panel/Flugzeug wieder hineingepackt und damit ist alles wieder in Ordnung. Trotzdem Danke für deine Mühe Oliver PS: Ich habe die Datei schon richtig installiert... ------------------ Meine Homepage jetzt mit FORUM (es werden noch Moderatoren gesucht)!!: Oliver's Flusi Site Zitieren
