Alle Cessna Single Engines von Henry Tomkievicz
Henry Tomkievicz hat ein riesiges Paket zusammengestellt, das ALLE single engine props von Cessna für den AI Verkehr enthält. Dazu noch weltweite Flugpläne um das ganze auch in den Flusi zu bringen. Die Featurliste ist einfach sagenhaft, es gibt aber einen Nachteil: Das Pack kostet 15 Euro. Gezahlt werden kann mit PayPal oder 2Checkout.com hier:
http://www.htaimodels.com/projects.html
Screenshots hier:
http://www.htaimodels.com/forum/view_topic.php?id=53&forum_id=5
Hier die Featureliste:
Cessna Single-Engine Props is one of the most comprehensive AI model projects developed for Microsoft's Flight Simulator© to date. Easily add the most popular series of general aviation aircraft in the world to your simulator's AI traffic at one time.
Features included:
• A total of 57 separate visual models covering Cessna's long production history of civilian single-engine aircraft.
• High quality visual models featuring low polygon counts with many models displaying less than 1000 polygons at LOD 1.
• Multiple levels of detail (LODs) for maximum AI traffic performance.
• Animated wheels, props, flaps, cowl flaps, landing gear, and control surfaces where applicable.
• Accurate animations of the unique Cessna retractable landing gear characteristics.
• Models featuring wheel pant and non-wheel pant versions where applicable.
• Models equipped with floats, floats with operating landing gear, skis, and tundra tires.
• Banner tower models of the 152 and 172 Skyhawk with conditionally appearing and user customizable banner message.
• Early and current late model production versions of the 182 Skylane and 206 Stationair.
• Updated models of the C208B Grand Caravan compatible with all current textures (also available as a free separate download).
• Specialized flight dynamics optimized for AI traffic use.
• Compatible with most third party aircraft manager programs.
• High quality and very detailed base textures.
• Very detailed layered Photoshop© (*.psd) paintkits.
• Generic textures for each model in DXT3 format without mipmaps.
• Generic textures for each model in 32-bit format so you can apply the registration of your choice.
• Basic flightplans to cover most of the world.
• Conditionally appearing tie down ropes, wheel chocks, and pitot tube covers.
• Navigation and strobe light effects specifically sized for small GA aircraft.
• Professional installer that places all components in their proper places with only a few mouse clicks.
• Choice of automatic or manual installation.
Ich habe das Paket auch gleich gekauft und installiert. Bei Bezahlung via PayPal und Bankeinzug (nicht für PayPal Erstkunden AFAIK) kann dar Download von 18MB sofort starten.
Zunächst zum weniger wichtigen, den Flugplänen Die Airportabdeckung könnte besser sein, da scheinbar keine Airports ohne AFCADs im Standard-FS verwendet werden. Aber wie sollte er es sonst machen? Ein neuer Flugplan ist ja mit Tools wie GA-Traffic, die auch alle AFCADs scannen, schnell erstellt und passt besser zur individuellen Konfiguration des Users.
Die Modelle halten aber wirklich jedes Versprechen und jeder der 33 Typen enthält meist 5 bis 10 repaints die von sehr guter Qualität sind. (Die Grand Caravan ist auch als Freeware erhältlich und kommt im Gegensatz zur Caravan ohne repaints. Macht aber nichts, die meisten sind eh Airliner und schon umgesetzt und auf AVSIM.) Die Modelle kommen in wirklich fast allen erdenklichen Varianten, es gibt Float- und Tundra-Versionen, Turbo, RG und etliche andere Varianten...Ich habe sogar eine Cessna die ein Banner zog gefunden!
Hier sind sie alle:
120
120 with wheel pants
140
140 with wheel pants
140A
140A with wheel pants
140A with tundra tires
140A with floats
150/152
150/152 with wheel pants
150/152 banner tower (with user customizable banner message)
170
170 with wheel pants
170A
170A with wheel pants
170B
170B with wheel pants
170B with floats
170B with tundra tires
170B with skis
172 early production model
172 early production model with wheel pants
172 Skyhawk
172 Skyhawk with wheel pants
172 banner tower (with user customizable banner message)
172RG Cutlass RG
177 Cardinal
177RG Cardinal RG
182 Skylane
182 Skylane with wheel pants
182 Skylane current production model
182 Skylane current production model with wheel pants
182RG Skylane RG
185 Skywagon
185 Skywagon with floats
185 Skywagon with floats and landing gear
185 Skywagon with tundra tires
185 Skywagon with skis
190/195 Businessliner
190/195 Businessliner with wheel pants
206 Stationair
206 Stationair with wheel pants
206 Stationair current production model
206 Stationair current production model with wheel pants
206 Stationair with floats
206 Stationair with floats and landing gear
207 Stationair 7/8
207 Stationair 7/8 with wheel pants
208 Caravan I
208 Caravan I with cargo pod
208 Caravan I with floats
208 Caravan I with floats and landing gear
208B Grand Caravan (improved model, no texture mapping changes)
208B Grand Caravan with cargo pod (improved model, no texture mapping changes)
210 Centurion
P210 Pressurized Centurion
P210 Pressurized Centurion with radar pod
Ich hoffe, ein paar von euch AI Freaks mit diesem Tip geholfen zu haben!
Erstens eine kleine Korrektur -- das Paket kostet 15$ und nicht Euro, das wären etwa 13 Euro.
Zweitens gibt es einen Patch (http://www.htaimodels.com) und die Paintkits (bei AVSIM).
Drittens gibt es bei AVSIM eine C177 Cardinal als kostenloses Probemodell und eine verbesserte Version der C208B Grand Caravan (die gab es ja schon vorher als Freeware).
