Transponder Mode S ?
Hallo zusammen,
Ist es möglich das ab märz 2008 auch für VFR Transponder mode S pflicht ist.
Gruss Hansjörg.
Gerne zitiere mal aus dem AIC 03/04 JAN 29 (Schweiz)
Das sind klare, eindeutige und bekannte Termine.
Grüessli
Joachim
2 Airborne Equipment Regulation
2.1 The carriage and operation of Mode S airborne equipment with Elementary Surveillance
functionality shall be mandatory in airspace designated by the appropriate ATS authorities as
follows:
a. For IFR flights, as General Air Traffic (GAT), a level 2 transponder, as a minimum, with
Elementary Surveillance functionality for aeroplanes issued with a first certificate of
airworthiness on or after 31st March 2004.
Note For operations in Swiss airspace, the date is 31st March 2005 instead of 31st March
2004.
b. For IFR flights, as General Air Traffic (GAT), a level 2 transponder, as a minimum, with
Elementary Surveillance functionality with effect from 31st March 2005, for aeroplanes
issued with a first certificate of airworthiness prior to 31st March 2004.
c. For VFR flights, conducted in airspace where the carriage and operation of SSR
transponders is already mandatory, a level2 transponder, as a minimum, with Elementary
Surveillance functionality for aeroplanes issued with a first certificate of airworthiness on or
after 31st March 2005.
d. For VFR flights, conducted in airspace where the carriage and operation of SSR
Surveillance functionality with effect from 31st March 2008, for aeroplanes issued with a first
certificate of airworthiness prior to 31st March 2005.
Transponder Mode S ist beschlossene Sache.
Für Deutschland fürchte ich nach dem Regierungswechel noch andere Änderungen in der Luftfahrt.
Mogäähn,
hier noch ein Link der den Mode S erklärt. Und auch gleich noch die Kostenseite aufzeigt..... Ganz schön happig was da auf Flugschulen und ähnliches zukommt.
http://www.eddh.de/topics/mode-s.html
@chaski. Gemäss diesem (http://www.lba.de/deutsch/technik/avionik/ModeS.htm) DFS Rundschreiben wurde Mode S schon vor den Wahlen in Germanien beschlossen. Alles kann man dieser neuen Bundesregierung nun wirklich nicht anlasten. ;-)
