Max1511 Geschrieben 17. September 2005 Geschrieben 17. September 2005 Hallo Zusammen Ich habe mir diese datei heruntergeladen: 380smoke.zip. Nun hat es nicht geklappt. Hier die Anleitung: General Instructions GENERAL INSTRUCTIONS ==================== This instructions will allow you to install smokes not only to the default aircraft but also to any other you wish except helicopters. 1.- Copy the Gauges and the Effects folders to the main folder of fs9 and let overwrite 2.- For default aircraft, copy to the aircraft.cfg of each one, the text contained in the file corresponding to each aircraft that appears in the Smokes for default folder. For the A380 the smokes are in the Smokes for A380 folder. 3.- When installing smokes on any other aircraft go to the aircraft.cfg file and search for: [GeneralEngineData] Check the number of engines. If 1: Engine.0=xxxx,xxx,xxx If 2: Engine.0=xxxx,xxx,xxx Engine.1=xxxx,xxx,xxx If 3; Engine.0=xxxx,xxx,xxx Engine.1=xxxx,xxx,xxx Engine.2=xxxx,xxx,xxx The example bellow is for 4 engines. [GeneralEngineData] 1 2 3 Engine.0=-48.6, -4.8, 0.8 Engine.1=-48.6, 4.8, 0.8 Engine.2=-37.23, -27.7, -2.20 Engine.3=-37.23, 27.7, -2.20 In engines the positions are: Column 1= Forward (-) Back Column 2= Right (-) Left Column 3= Up (-) Down [sMOKESYSTEM] 1 2 3 smoke.0= 0.8, -48.6, -4.8, fx_smoke_ys11 smoke.1= 0.8, -48.6, 4.8, fx_smoke_ys11 smoke.2=-2.20, -37.23, -27.70, fx_smoke_ys11 smoke.3=-2.20, -37.23, 27.70, fx_smoke_ys11 In smoke positions are: Column 1= Up (-) Down Column 2= Forward (-) Back Column 3= Right (-) Left You can use any kind of smoke you like better. There are lots of them available for FS2002 that will work in 2004 just the same I enclose the ones I like best: fx_smoke_rx_pc -----------Gray fx_smoke_w ---------------White fx_smoke_ys11 -----------Another kind of gray (this I prefer) fx_smoke_r ---------------Red Seite 1 General Instructions fx_smoke_rx --------------A darker kind of gray IMPORTANT NOTE ============== Be aware of NOT writting the .fx next to the effect in the Aircraft.cfg or effect will not appear. Example: "fx_smoke_r.fx" effect must be copied fx_smoke_r in Smokesystem Example of Smokesystem in Lear 45: [GeneralEngineData] engine_type = 1 Engine.0 = -42.8, -4.8, 0.8 Engine.1 = -42.8, 4.8, 0.8 fuel_flow_scalar= 1.0 min_throttle_limit = -0.25 [sMOKESYSTEM] smoke.0=0.8,-42.8,-4.8, fx_smoke_rx (It is not fx_smoke_rx.fx) smoke.1=0.8,-42.8,4.8, fx_smoke_rx 4.- AUTOSMOKE GAUGES Depending of the kind of engines of the aircraft the gauge to add to the panel.cfg would be: gaugexx=Autosmoke!JetSmoke,11,250,44,44 ----- //For Jets gaugexx=Autosmoke!PistonSmoke,11,250,44,44 ----- //For Propellers gaugexx=Autosmoke!TurboSmoke,11,250,44,440 ----- //For Turbo Props Example: In Lockheed Vega which is a piston you add at the end of [Window00] gaugexx=Autosmoke!PistonSmoke, 0,0 and change the xx for the number of the gauge to follow to the last one, in this case 31 [Window00] file=vega_background.bmp size_mm=1024, 768 position=7 visible=1 ident=MAIN_PANEL gauge00=Lockheed_Vega!magneto_switch, 0, 626 gauge01=Lockheed_Vega!oat, 126, 503 gauge02=Lockheed_Vega!oil_temp, 127, 591 gauge03=Lockheed_Vega!manifold_pressure, 218, 436 gauge04=Lockheed_Vega!rpm, 218, 558 gauge05=Lockheed_Vega!oil_pressure, 171, 683 gauge06=Lockheed_Vega!fuel_pressure, 266, 683 gauge07=Lockheed_Vega!adf, 333, 330 gauge08=Lockheed_Vega!cyl_temp, 364, 683 gauge09=Lockheed_Vega!altimeter, 454, 330 gauge10=Lockheed_Vega!vsi, 459, 683 gauge11=Lockheed_Vega!asi, 576, 330 gauge12=Lockheed_Vega!turn_and_bank, 554, 683 gauge13=Lockheed_Vega!suction, 649, 683 gauge14=Lockheed_Vega!gyro_compass, 692, 439 gauge15=Lockheed_Vega!main_panel_switches, 689, 601 gauge16=Lockheed_Vega!clock, 745, 683 gauge17=Lockheed_Vega!magnetic_compass, 813, 503 gauge18=Lockheed_Vega!ammeter, 841, 683 gauge19=Lockheed_Vega!trim, 880, 600 gauge20=Lockheed_Vega!voltmeter, 935, 683 gauge21=Lockheed_Vega!sperry_autopilot, 345, 462 gauge22=SimIcons1024!Kneeboard Icon, 707, 560 gauge23=SimIcons1024!ATC Icon, 730, 560 gauge24=SimIcons1024!Map Icon, 753, 560 gauge25=SimIcons1024!GPS Icon, 777, 560 gauge26=SimIcons1024!Radio Icon, 707, 582 gauge27=SimIcons1024!Throttle Quadrant Prop Icon, 730, 582 gauge28=SimIcons1024!Fuel Panel Icon, 753, 582 gauge29=SimIcons1024!ADF Receiver Icon, 777, 582 gauge30=Cessna208!Nav-GPS-Switch, 955, 645 gauge31=Autosmoke!PistonSmoke, 0,0 The same procedure has to be done with each and every panel of the default aircraft. 5.-In order to know if an aircraft is jet, propeller or turbo prop open the aircraft.cfg and if you find this sections it is a turbo prop: [propeller] [TurbineEngineData] [turboprop_engine] When it is propeller you will find: [piston_engine] [propeller] When jet only: [TurbineEngineData] Ab Punkt 2 weiss ich nicht, was ich richtig gemacht habe und was nicht. Kann mir jemand helfen? Besten Dank. Zitieren
Max1511 Geschrieben 28. April 2006 Autor Geschrieben 28. April 2006 Hallo Kann mich wirklich niemand helfen. Dieses Problem ist noch aktuell. Zitieren
rolfuwe Geschrieben 28. April 2006 Geschrieben 28. April 2006 Eigentlich habe ich keinen Fehler bemerkt. Aber wenn ich so etwas noch nie gemacht hätte, würde ich mit der Beschreibung auch Proleme haben. gauge31=Autosmoke!PistonSmoke, 0,0 würde ich in das VC stecken, weil es so vermutlich nur funktioniert wenn man das 2D-Panel in der Ansicht hatte und dann in der Beobachteransicht erst den Smoke sieht. Wenn die Effects installiert sind, muß das ...Smoke.gau ins panel und [sMOKESYSTEM] smoke.0= 0.8, -48.6, -4.8, fx_smoke_ys11 smoke.1= 0.8, -48.6, 4.8, fx_smoke_ys11 smoke.2=-2.20, -37.23, -27.70, fx_smoke_ys11 smoke.3=-2.20, -37.23, 27.70, fx_smoke_ys11 in die Aircraft.cfg wobei hier die Triebwerkskoordinaten mit den vertauschten Column verwendet werden. Ein Fehler ist evtl. bei der Smoke-Höhe, Die muß evtl im Effect geändert werden. notfalls müssen wir es mal an einem default Aircraft testen Uwe Zitieren
Max1511 Geschrieben 28. April 2006 Autor Geschrieben 28. April 2006 Hallo Uwe Was meinst du mit "würde ich in das VC stecken"? Also, ich hab mal das so gemacht. Punkt 1 ist klar. Dann habe ich aus dem Ordner "Smokes for A380" die Datei "a380-800 Smoke.txt" geöffnet und folgendes kopiert: [sMOKESYSTEM] 1 2 3 smoke.0= 6.1, -2.9, -85.570000, fx_smoke_ys11 smoke.1= 2.54, 23.460000, -50.19, fx_smoke_ys11 smoke.2= 2.54, 23.460000, 50.19, fx_smoke_ys11 smoke.3= 6.1, -2.9, 85.570000, fx_smoke_ys11 Diesen habe ich dann im aircraft.cfg kopiert und zwar nach dem Eintrag "GeneralEngineData". Da der A380 ein Jet ist, habe ich den Text "gauge59=Autosmoke!JetSmoke,11,250,44,44" in der panel.cfg eingefügt und zwar beim Eintrag "Window00". Und nun sollte es funktionieren. Das komische ist, dass 1. nur die rote Farbe zu sehen ist (die anderen nicht) und 2. das ich dauernd die Taste "I" drücken muss, damit die Streifen erscheinen. Doch es sollte automatisch funktionieren. Was nun? Zitieren
rolfuwe Geschrieben 29. April 2006 Geschrieben 29. April 2006 Frage: sind die Effects Kondensstreifen oder Abgas-smoke? Kondensstreifen macht der Flusi schon. Mit einem Smoke.gau im Panel und dem Smokeeintrag in der Aircraft.cfg macht man eigentlich Abgasrauch. Eigentlich funktioniert es schon bei Dir. Smoke.gau übernimmt die Funktion der Taste "I". Im GAU sind die Bedingungen vorgegeben, wann der Smoke funktioniert. Die kenne ich nicht. Aber evtl. ist es die Triebwerksleistung. Im Effect steht, wie der Smoke aussieht und von wo er sich wie ausbreitet. Da müßte jetzt die" rote Farbe" definiert sei. Ist schon komisch. Aber da ich die Dateien nicht kenne, kann ich dazu nichts sagen. Wir sollten besser über Mail weitermachen, weil ich nicht regelmäßig in`s Forum gucke. Zitieren
Max1511 Geschrieben 14. November 2006 Autor Geschrieben 14. November 2006 Hallo Zusammen Ich habe wieder eine Frage zu diesem Thema. Nun habe ich alles gemäss Anleitung installiert. Nun habe ich aber bemerkt, dass nicht alle *.fx Smoke-Dateien funktionieren. Das heisst: Wenn ich zum Beispiel auf die "iFDG_A320_flap.fx" verweise, wird der Abgasrauch beim drücken auf "I" ersichtlich. Nur ist dieser Abgasrauch zu dünn für den A380. Wenn ich aber auf die Datei "fx_smoke_ys11.fx" verweise, funktioniert das ganze nicht mehr. So sieht die "fx_smoke_ys11.fx" aus: [Library Effect] Lifetime=5 Version=1.00 [Emitter.0] Lifetime=0.00, 0.00 Delay=0.00, 0.00 Bounce=0.00 Rate=44.00, 66.00 X Emitter Velocity=0.00, 0.00 Y Emitter Velocity=0.00, 0.00 Z Emitter Velocity=0.00, 0.00 Drag=0.00, 0.00 X Particle Velocity=0.00, 0.00 Y Particle Velocity=0.00, 0.00 Z Particle Velocity=0.00, 0.00 X Rotation=0.00, 0.00 Y Rotation=0.00, 0.00 Z Rotation=0.00, 0.00 X Offset=0.00, 0.00 Y Offset=0.00, 0.00 Z Offset=0.00, 0.00 [Particle.0] Lifetime=2.00, 8.50 Type=19 X Scale=1.00, 1.50 Y Scale=1.00, 1.50 Z Scale=3.00, 3.50 X Scale Rate=0.50, 1.00 Y Scale Rate=0.50, 1.00 Z Scale Rate=0.00, 0.00 Drag=-4.00, -3.98 Color Rate=0.33, 0.45 X Offset=0.00, 0.00 Y Offset=0.00, 0.00 Z Offset=0.00, 0.00 Fade In=0.00, 0.00 Fade Out=0.55, 0.57 Rotation=-180.00, 180.00 Shade=1 Face=1, 1, 1 [ParticleAttributes.0] Blend Mode=1 Texture=fx_1.bmp Bounce=0.00 Color Start=75, 75, 75, 5 Color End=75, 75, 75, 0 Jitter Distance=0.00 Jitter Time=1.00 TempK=107.00 TempRate=0.01 uv1=0.50, 0.75 uv2=0.75, 1.00 X Scale Goal=3.00 Y Scale Goal=2.00 Z Scale Goal=1.00 Extrude Length=3.00 Extrude Pitch Max=0.00 Extrude Heading Max=0.00 Weiss jemand, was in dieser Datei falsch sein könnte? Zitieren
