Anleitung DF737 + Jet Line 4 gesucht!
Hallo zusammen,
ich suche wie der Titel schon sagt, die Anleitung zum mergen der DF737
in Verbindung mit der von Reality XP vertriebenen Jet Line 4 Gauges. Ich hab gestern schon das Forum durchsucht u. auch einiges gefunden, aber eben nicht die gesamte Anleitung! Wäre nett, wenn mir jemand helfen könnte! Auf der Homepage von reality xp sind die files leider nicht mehr verfügbar!
Mike
Hoi Mike
Hier die Anleitung:
Gruss Patrick
- Greatest Airliners! 737-400 will install a version of FSUIPC.dll not compatible with FS2004. If you use the module already, back up your existing FSUIPC.dll file if you want to keep it. The most actual version can always be found at http://www.schiratti.com/dowson
- Install your Greatest Airliners! 737-400 Package to FS2004. If you have the FS2000 version, install the FS2002 update as well
- Download and install any of the FFX B737-400 aircraft to FS2004 You may find them at http://sgair.net/B737
- Install the Reality XP Jet Line 4 Version 2.0 to FS2004
- delete the model and texture.xxx folders from ...\Flight Simulator 9\aircraft\Flight One 737-400
- copy the model and the texture.xxx folders from the FFX aircraft to ...\Flight Simulator 9\aircraft\Flight One 737-400
- rename the texture.xxx folder to texture
- extract the contents of the panel.zip to ...\Flight Simulator 9\aircraft\Flight One 737-400\panel (overwrite existing files)
- extract the contents of the aircraft.zip to ...\Flight Simulator 9\aircraft\Flight One 737-400 (overwrite existing files)
- create a ...\Flight Simulator 9\Pilots folder
- create a ...\Flight Simulator 9\Flights\myflts
You have three options to deal with the FSUIPC.dll module
- if you don´t need the module, delete the FSUIPC.dll file from ...\Flight Simulator 9\modules\
- if you have registered FSUIPC with Pete Dowson, add the line "MakeItVersionFS2002=YES" to your FSUIPC.ini file
- if you want to continue using an unregistered version of FSUIPC, rename FSUIPC.dll to FSUIPC737.dll
- load FS2004, you´ll find your new aircraft manufactured by "FFX and DF2000"
Mensch Patrick, du weißt ja gar nicht was du mir für einen Gefallen getan hast! Ich danke dir!
Ich glaube ich hab mit Sicherheit um die 10 Std. in div. Foren versucht diese Anleitung zu finden!
wo genau finde ich denn diese panel.zip u. aircraft.zip datei? Wenn Sie jemand hat, wäre ich sehr dankbar wenn Ihr sie mir schicken könntet!
MWAG12@t-online.de
