Panelproblem
Ich habe mir die Fedex MD11 von avsim.com heruntergeladen + panel für fs 2004. fedex maschine funzt, aber panel wird nicht angezeigt (stattdessen Boeing 747 - Panel) Also das Panel is für MD10 und 11 konzipiert, die Maschine ist eine MD11 - F. Gehts darum nicht, oder woran liegt das? Ich hab alle Anweisungen beim readme befolgt. Falls es was bringt: hier ist es:
\par
\ul English:\par
\par
\cf0\ulnone Warning: for MS Flight Simulator 2004 only\par
\par
Installation:\par
\par
Unzip the file md11_pan.zip in a temporary folder.\par
Paste and copy the gauges folder into the main FS9 folder (overwrite if requested).\par
Item paste and copy the sound folder into the main FS9 folder (overwrite if requested).\par
Item paste and copy the Modules folder into the your main FS9 folder (overwrite if requested).\par
Put the panel folder into the your MD-11 aircraft.\par
\par
That is all.\par
Enjoy and good fly\par
\par
---------------------------------------------------------------------------------------------------------------------------------\par
\cf2\ul\b\fs22 GAUGES AUTHORS\ulnone\par
\b0\par
Many thanks to all the authors of the gauges and pictures used in this panel:\par
\cf0\f1\fs20\par
\b Microsoft Corporation\par
Ken Mitchell\par
Andreas Jaros (FPDA)\par
Richard Probst\par
Jorge Salas\par
Alex Bashkatov (Flightsim Developers)\par
HGHB Virtual Instruments\b0\par
\b ERK Panels\par
Tony D'Ambrosio (Piane Corporation)\par
Mike Weerasinghe\par
Peter Beddig\par
Melville Consulting\par
DragonFly Design\par
Eric Marciano\par
Alex Backfire (Flightsim Developers)\par
Bluesky Software Development (STZ KC)\par
Dome Fliteware\par
Mike Stone (Bluesky Software Developers)\par
\par
\cf1\f0\par
\cf0\b0\f1 ========================================================================================\par
\par
\cf2\b\f0\fs22 COPYRIGHT\par
\cf0\f1\par
\b0\fs20 This software is released as Freeware. Copyright Antonio Bucoli. As freeware you are permitted to distribute this archive subject to the following conditions:\par
- The archive must be distributed WITHOUT ANY MODIFICATION to the contents of the archive. Redistributing this archive with any files added, removed or modified is prohibited, except as specified under.\par
- The inclusion of any individual file from this archive in another archive without the prior permission of the author is prohibited\par
- No charge may be made for this archive other than that to cover the cost of its distribution. If a fee is charged it must be made clear to the purchaser that the archive is freeware and that the fee is to cover the distributor's costs of providing the archive. \par
All trademarks and logos presented are copyrighted by their respective owners.\par
\par
\f0\fs24\par
\par
Antonio Bucoli\par
[MED_0149 Chief Captain]\line e-mail: tonylicj@tiscali.it \par
\par
January 2004\f2\fs20\par
So, wenn ich das auch noch kann, hab ich momentan keine Fragen mehr und lass euch in Ruhe :005:
Oliver
genau, das liegt meistens daran, dass die Panel.cfg nicht richitg ausgetauscht wurde
Also ich habs jetzt nicht grad giffbereit (auf nem anderen compi), aber ich habe nur eine panel.cfg unter der MD11 im Ordner panel, ansonsten sehe ich nichts von wegen panel. das alte panel.cfg, das mit dem model gedownloadet wurde, hab ich wohl gelöscht. War das ein Fehler? Ich werdedas neue panel.cfg noch genau anschauen. Ich hab auch schon versucht im aircraft.cfg irgendwas so zu verändern, dass das neue panel verwendet wird, funzt aber nicht.
hallo,
In der Aircraft.cfg musst du nichts verändern. Wenn die Panel.cfg stimmt sollte das ganze funktionieren...
mfg tobi
Jo. Also die panel.cfg ist riesig und ich versteh nicht mal die Hälfte, aber irgendwie sieht alles gut aus, s wird wahrscheinlich irgendwo eine Zeile korrigiert werden müssen. Falls es was bringt: Hier ist die Datei (dieses panel.cfg ist mit dem Panel gedownloadet und im Ordner panel in den Ordner vonder MD11 eingefügt):
// Panel.cfg file created by Antonio Bucoli Saturday, February 28, 2004 at 23:16
// Built with FS Panel Studio - http://www.fspanelstudio.com
[Window Titles]
Window00=Main Panel
Window01=Oil Panel
Window02=Overhead Panel
Window03=GPS
Fixed Window33=Cabin
[VIEWS]
VIEW_FORWARD_WINDOWS=34,30,31,32
VIEW_FORWARD_ZOOM=0.7
VIEW_REAR_WINDOWS=33
VIEW_REAR_ZOOM=1.5
[Window00]
size_mm=1024,768
window_size_ratio=1.000
position=7
visible=1
ident=34
window_size= 1.000, 1.000
window_pos= 0.000, 0.000
gauge00=cpt.icons!ATC, 967,375,15,9
gauge01=cpt.icons!Map, 989,375,15,9
gauge02=cpt.icons!Checklist, 1009,375,14,9
gauge03=cpt.toggles.lear!FlightDirector, 506,320,16,11
gauge04=cpt.toggles.lear!IdentADF, 551,372,16,11
gauge05=cpt.toggles.lear!IdentNAV1, 530,372,16,11
gauge06=cpt.toggles.lear!IdentNAV2, 572,372,16,11
gauge07=cpt.toggles.lear!IdentDME1, 530,389,16,11
gauge08=cpt.toggles.lear!IdentDME2, 572,389,16,11
gauge09=cpt.toggles.lear!IdentMarker, 551,389,16,11
gauge10=cpt.toggles.lear!NAV-GPS, 506,338,16,11
gauge11=cpt.toggles.lear!AutoCoordinationToggle, 505,355,16,11
gauge12=cpt.toggles.lear!Exits, 505,389,16,11
gauge13=cpt.toggles.lear!Gear, 796,537,15,16
gauge14=cpt.toggles.lear!Chase, 505, 372 ,16,11
gauge15=CPT.PB.PFD, 155,471,172,172
gauge16=CPT.REAL.CRT, 352,470,168,169
gauge17=lear45alx_apalt, 859,397,15,9
gauge18=lear45alx_ath, 942,323,15,9
gauge19=lear45alx_bak, 564,348,15,9
gauge20=lear45alx_hdg, 701,396,15,9
gauge21=lear45alx_ias, 642,396,15,9
gauge22=lear45alx_lvl, 942,374,15,9
gauge23=lear45alx_mch, 942,340,15,9
gauge24=lear45alx_nav, 537,348,15,9
gauge25=lear45alx_yd, 942,357,15,9
gauge26=pg.APALTS, 810,340,46,9
gauge27=pg.APCRSS, 539,332,36,9
gauge28=pg.APHDGS, 689,339,37,10
gauge29=pg.APVSPS, 875,340,46,10
gauge30=pg.mdxx.cd.spd, 640,368,17,17
gauge31=pg.mdxx.cd.crs, 594,371,14,14
gauge32=pg.mdxx.cd.alt, 827,367,17,16
gauge33=pg.mdxx.cd.hdg, 698,365,17,16
gauge34=MD83_AP!Autopilot VS Selector, 880,359,31,39
gauge35=MD83_AP!Autopilot IAS-Mach Window, 624,335,50,17
gauge36=F16!Radar, 924,688,91,62
gauge37=F16!Radar Mode, 920,754,35,11
gauge38=F16!Radar Range, 974,753,32,10
gauge39=717!Autopilot, 738,399,30,13
gauge40=717!Autopilot, 771,399,30,13
gauge41=717_CALLSIGN!Tail_Number, 368,423,73,29
gauge42=md11_appr!md11_appr, 751,344,36,11
gauge43=md11_ap!md11_ap, 740,364,57,12
gauge44=md11_gearlt!md11_gearlt, 753,463,52,33
gauge45=FPDA_Gear_sound, 0,0,10,10
gauge46=FPDA_Gear_Wind, 0,0,10,10
gauge47=CAUT, 335,357,11,11
gauge48=WARN, 361,357,11,11
gauge49=Autobrake!Autobrake.Light, 358,334,20,7
gauge50=Ala_max!auto_land, 590,329,16,11
gauge51=Rp733!autobrake, 383,332,46,40
gauge52=TA747-400.NDSW, 459,365,38,34
gauge53=DC10PG.HGHB_SPEEDBR, 347,384,13,12
gauge54=SR71.Radios, 543,679,108,98
gauge55=MD-11.Gear-Handle, 741,501,50,130
gauge56=MD-11.Overspeed, 130,357,53,20
gauge57=MD-11.Stall, 200,355,53,20
gauge58=MD-11.Stby-Attitude, 797,695,59,59
gauge59=MD-11.Synop-a, 834,475,178,129
gauge60=MD-11.TEMPERATURE, 832,605,70
gauge61=MD-11.Trim-Units, 881,604,57,21
gauge62=MD-11.Chron, 832,624,110,92
gauge63=MD-11.Flap-Spoiler, 936,597,69,46
gauge64=md11_mfd1!md11_mfd1, 554,468,160,175
gauge65=c17.pt.30, 971,332,16,9
gauge66=c17.pt.31, 997,333,16,9
gauge67=c17.pt.32, 972,350,16,9
gauge68=c17.pt.33, 998,351,16,9
gauge69=c17.pt.34, 942,392,16,9
gauge70=MD-11.Stby-Altimeter, 698,689,77
[Window01]
size_mm=1024,768
position=7
visible=0
ident=30
gauge00=md11_mfd2!md11_mfd2, 844,467,160,176
[Window02]
size_mm=1024
position=2
visible=0
ident=31
window_size= 0.850, 0.850
window_pos= 0.150, 0.000
gauge00=cpt.toggles.land!LandingLights, 421,665,27,43
gauge01=cpt.toggles.land!LandingLights, 460,667,27,43
gauge02=cpt.toggles.land!TaxiLights, 510,666,27,43
gauge03=cpt.toggles.light.square!Battery, 326,192,23,13
gauge04=cpt.toggles.880.starter!PanelLights, 295,610,37,41
gauge05=cpt.toggles.880.starter!PanelLights, 293,671,38,43
gauge06=cpt.toggles.880.starter!IdentNAV1, 107,129,30,34
gauge07=cpt.toggles.880.starter!IdentMarker, 163,129,30,34
gauge08=cpt.toggles.880.starter!IdentNAV2, 219,129,30,34
gauge09=cpt.toggles.880.starter!ElectricVacuumPump, 91,324,34,39
gauge10=cpt.toggles.880.starter!ElectricVacuumPump, 203,325,34,39
gauge11=cpt.toggles.avncs!IdentNAV1, 117,107,19,11
gauge12=cpt.toggles.avncs!IdentNAV2, 226,106,21,12
gauge13=cpt.toggles.avncs!IdentMarker, 171,107,19,11
gauge14=hecpt.toggles.lear!BeaconLights, 673, 686 ,22,21
gauge15=hecpt.toggles.lear!LogoLights, 645,687,21,21
gauge16=hecpt.toggles.lear!NavLights, 616,686,22,22
gauge17=hecpt.toggles.lear!WingLights, 559,687,22,21
gauge18=hecpt.toggles.lear!WingLights, 587,687,24,21
gauge19=hecpt.toggles.lear!StrobeLights, 701,685,22,22
gauge20=hecpt.toggles.lear!Fuel Pump 1, 342,473,24,25
gauge21=hecpt.toggles.lear!Fuel Pump 2, 450,474,25,25
gauge22=hecpt.toggles.lear!Fuel Pump 3, 558,474,26,25
gauge23=hecpt.toggles.lear!Fuel1, 309,473,24,25
gauge24=hecpt.toggles.lear!Fuel2, 417,474,25,25
gauge25=hecpt.toggles.lear!Fuel3, 526,475,25,24
gauge26=hecpt.toggles.lear!Avionics, 657,193,22,22
gauge27=hecpt.toggles.lear!StartJet1, 164,546,22,24
gauge28=hecpt.toggles.lear!StartJet2, 191,546,22,25
gauge29=hecpt.toggles.lear!StartJet3, 218,547,22,24
gauge30=hecpt.toggles.lear!DeIce, 744,443,21,23
gauge31=hecpt.toggles.lear!DeIce, 799,442,23,23
gauge32=hecpt.toggles.lear!PitotHeat, 744,485,22,23
gauge33=hecpt.toggles.lear!PitotHeat, 801,485,23,22
gauge34=hecpt.toggles.lear!Autopilot ALT, 178,273,22,23
gauge35=hecpt.toggles.lear!Autopilot HDG, 204,274,22,23
gauge36=hecpt.toggles.lear!Autopilot NAV, 231,274,22,23
gauge37=hecpt.toggles.lear!FuelTanks, 377,512,25,25
gauge38=hecpt.toggles.lear!FuelTanks, 486,513,25,25
gauge39=hecpt.toggles.lear!FuelTanks, 595,513,25,25
gauge40=He_apugen1, 366,234,23,40
gauge41=He_apugen2, 471,235,23,40
gauge42=He_Aircond, 374,414,25,55
gauge43=He_Aircond_0001, 483,416,26,53
gauge44=He_Aircond_0002, 591,416,26,53
gauge45=no-smoking, 466,610,22,41
gauge46=seat-belts, 507,611,22,41
gauge47=fuel.left, 315,519,44,13
gauge48=fuel.right, 532,520,44,13
gauge49=attend, 742,605,23,48
gauge50=747RT.sw_cpit_voice_recorder, 216,199,9,20
gauge51=ID_747_PaxPnl2!ID_747_PaxPnl, 543,605,137,51
gauge52=enfire1, 197,604,41,43
gauge53=enfire2, 273,541,41,43
gauge54=enfire3, 663,543,41,43
gauge55=FPDA_W_switch, 781,618,40,40
gauge56=FPDA_W_switch_1, 139,619,40,40
gauge57=FPDA_W_switch_2, 306,343,33,34
gauge58=FPDA_W_switch_3, 658,235,33,33
gauge59=FPDA_W_switch_4, 413,345,33,34
gauge60=FPDA_W_switch_5, 520,346,33,34
gauge61=FPDA_W_switch_6, 626,344,33,34
gauge62=FPDA_W_switch_7, 730,136,35,35
gauge63=FPDA_W_switch_8, 841,139,35,35
gauge64=md11_deice!md11_deice, 771,442,23,24
gauge65=md11_master!md11_master, 296,192,27,32
gauge66=DFD_Gen_Light.1, 74,548,19,19
gauge67=DFD_Gen_Light.2, 103,549,19,19
gauge68=DFD_Gen_Light.3, 134,550,19,19
gauge69=DFD_Ice_Warn1, 838,444,18,17
gauge70=DFD_Ice_Warn1_0001, 866,443,18,17
gauge71=DFD_Ice_Warnup, 775,487,18,18
gauge72=Rp733!hydraulic, 729,322,160,100
gauge73=0.0.p51.amp, 152,174,39,39
gauge74=BOEING747-400.apu_start, 662,414,46,46
gauge75=dc_concorde.fueltotal, 426,516,40,20
gauge76=a300.air-brake, 733,109,20,18
gauge77=A-310.Cabin-Press, 708,-5,77,77
gauge78=A-310.L-AC-Pack, 415,408,24,23
gauge79=A-310.L-Feed-Switch, 372,447,33,57
gauge80=A-310.R-AC-Pack, 523,394,24,24
gauge81=A-310.R-Feed-Switch, 590,447,33,57
gauge82=cpt.toggles.880.switch!Dummy, 380,619,26,29
gauge83=Hdghud, 383,683,18,16
gauge84=cpt.toggles.880.switch!Autopilot YAW, 249,671,26,29
gauge85=FPDA_W_switch_9, 298,269,40,40
gauge86=He_apugen3, 575,236,23,40
gauge87=He_dum.0, 347,264,23,40
gauge88=He_dum.1, 385,264,23,40
gauge89=He_dum.2, 453,206,23,30
gauge90=He_dum.3, 491,206,23,30
gauge91=He_dum.4, 557,207,23,30
gauge92=He_dum.5, 593,207,23,30
gauge93=He_dum.6, 452,268,23,30
gauge94=He_dum.7, 490,269,23,30
gauge95=He_dum.8, 526,269,22,36
gauge96=He_dum.9, 557,270,23,30
gauge97=He_dum.10, 594,270,23,30
gauge98=He_dum.11, 386,206,21,27
gauge99=md11_gen1!md11_gen1, 346,294,25,24
gauge100=md11_gen2!md11_gen2, 451,296,24,22
gauge101=md11_gen3!md11_gen3, 557,297,25,22
gauge102=cpt.toggles.light.square!Alternator1, 363,358,23,20
gauge103=cpt.toggles.light.square!Alternator2, 470,358,23,20
gauge104=cpt.toggles.light.square!Alternator3, 577,359,23,20
gauge105=He_dum.12, 420,192,22,36
gauge106=He_dum.13, 523,193,22,35
gauge107=He_dum.14, 421,124,21,33
gauge108=He_dum.15, 523,139,21,33
gauge109=He_dum.16, 667,344,20,32
gauge110=He_dum.17, 668,386,21,33
gauge111=He_dum.18, 633,397,21,33
gauge112=He_dum.19, 634,432,20,39
gauge113=He_apugen4, 524,432,22,36
gauge114=He_dum.20, 665,476,21,37
gauge115=il86-DFD_Fuel_Low_Left_Main, 407,548,23,60
gauge116=il86-DFD_Fuel_Low_Right_Main, 622,548,23,60
gauge117=pg.mdxx.cd.gdoor, 811,550,17,18
gauge118=pg.mdxx.fpda.cabinpress, 292,232,64
gauge119=pg.mdxx.go.oh.hyd, 731,248,41,41
gauge120=DFD_jetmaster, 777,158,48,21
gauge121=A-310.X-Feed, 481,447,33,57
gauge122=MD-11.Fuel1-Icon, 341,558,12,43
gauge123=MD-11.Fuel2-Icon, 450,558,12,43
gauge124=MD-11.Fuel3-Icon, 560,558,12,43
gauge125=IL86-DFD_Fuel_Low_Centre, 516,553,23,60
gauge126=f162k_pb_31, 990,4,17,18
[Window03]
size_mm=250
position=0
visible=0
ident=32
window_size= 0.280, 0.270
window_pos= 0.720, 0.600
gauge00=fs9gps!gps_500, 0,0,250,207
[Fixed Window33]
position=7
visible=0
ident=33
render_3d_window=1
Day=255,255,255
Night=118,96,39
Luminous=120,68,68
[Default View]
X=0
Y=0
SIZE_X=8191
SIZE_Y=2717
Ist das eigentlich noch erlaubt? Sorry, aber ich hab keine grosse Ahnung von diesen Dateien. Wer den Fehler zuerst findet, bekommt ein dickes Lob!
Oliver
