Piaggio P-166 All Versions New Flight Dynamics + HTML Handbook Reference
hallöchen
Soviel ich weiss haben ganz viele Piloten diesen Vogel auf der Platte. Hier gibt es den Update
Thanks to Andrew Spring of http://www.p166.com!! This is a massive update for the Piaggio P-166 Series aircraft. This Package contains a whole update for ALL the models,(P-166A\M\S\BL2\CL2\DL3\DL3-SEM\DP1) and a pilot handbook in html format. You can read it in the full large version or in the reduced size version re-adapted for the electronic FS2004 kneeeboard as "Reference". All aircraft refer to the same file, so after the introdution to the P-166 and her main characteristics, individual links to the single P-166 versions are included (only "Kneeboard" version). The main improvements in the FDEs are a nice stability making the plane just fly strigght-and-leveled easily, re-calibrated flap and fuselage drags, wich makes for better max speed and landing characteristics. Also flaps and landing gear pitch moments are lots reduced. Now the plane respects the Specs of the real thing completly, even matching the changes from version to version!! in newer versions, engine power output has been recalculated, as well as new payloads and fuel capacities: you can litterally load the passangers and baggage you wish...but don't try to exaggerate, going overweight is not that complex...for instance, try placing a 9999 pounds copilot and guess what happens... Happy Flights!!
mfg tobi
