Felix Hippmann Geschrieben 28. Mai 2004 Geschrieben 28. Mai 2004 Hallo! Damian Clark ist schon wieder fleißig gewesen - im Forum gibt es die Beta-Version des nächsten Patches "Maintenance Release 2" (MR2) zum Download. Diese Version ist aber noch experimentell! MR2 beta Version Interessanterweise kann ActiveSky2004 nun auch die Informationen aus zusätlichen METAR-Tags der Art //// CLD verstehen. - Added full FSFlightMax v1.4r integration for AS2004 use with this freeware Radar/GPS Mapping software. When using FSFlightMax, follow the important instructions available in the in ActiveSky-FSFlightMax_Integration.pdf included in the FSFlightMax installation folder.- When TAF processing was enabled, ActiveRadar could misinterpret the METAR information and display invalid data / radar returns. Fixed. - Extended length of time that AS2004 waits for FS9 to load/reload before writing wx. Previously, a lengthy FS9 load could cause AS2004 to give up and present invalid current/departure wx conditions. - Fixed problem with interpolation in areas with very few stations (less than 5 in a 300nm radius - such as near YBBN), which could cause wx consistency/precipitation problems. - Added warning message: NORMAL DEFAULTS button causes ONLINE UPDATES to be turned off, so it must be manually re-enabled after loading defaults (if live downloads are desired). - Fixed upper level temperature problem with route-based wind smoothing - Added automatic .PLN convert to FS9 format option, to automatically convert to proper ActiveRadar-compatible .PLN data as soon as the flight plan is loaded via the NEW ROUTE/IMPORT processes. This prevents the user from having to load and re-save the .PLN in FS9 with 3rd-party flight plan generators. - Added new experimental METAR data support (//// CLD used in certain areas (YBCG, for example) to enable proper cloud and visibility depiction. Zum Beitrag im Avsim-Forum geht es hier. Viel Spaß! Felix Zitieren
