blackswan Geschrieben 8. März 2004 Teilen Geschrieben 8. März 2004 hallöchen Norfolk International Airport for FS2004/FS9 is finally here! This package contains many improvements over previous versions including new taxiway/apron surfaces, reduced polygon count, correction of default roads/waterlines, a new AFCAD2, and even the I-64 bridge at the end of runway 23. If you haven't flown Norfolk yet, come out and see what flying one of the nation's top 65 airports is all about! (Requires Gerrish Gray's trees_v3.zip) (JW) http://library.avsim.net/esearch.php?DLID=45474&CatID=Root Die Webpage des Airport findet man hier mfg tobi Zitieren Link zu diesem Kommentar Auf anderen Seiten teilen Mehr Optionen zum Teilen...
