FS2004: 5 neue LSxx-Airports
hallo freunde...
...heute am 13.09. wurden von andreas hegi folgende fs2004(!)-szenerien bei
 www.avsim.com eingespielt:
bern-belp:
This is my third version for Bern-Belp with the finished new terminal, new parking lines,
additional buildings, fences and several airport ground vehicles and new roads to make it
compatible with FS2004. Most of the textures are in DXT1 format for good frame rates. The
Bantiger telecom tower is also included. Previous version had over 4300 downloads. ®
hausen am albis:
Very detailed and accurate small airfield with a unique atmosphere with an asphalt and a
grass runway close to the city of Zug in the centre of Switzerland with the newest textured
airport buildings and a monastery all made by digital photographs. The autogen scenery has
been modified to show correct forests, fields, towns and roads. Static aircrafts and gliders
cars and caravans smoke effects dynamic wind sail and a visual approach chart are available. ®
luzern-beromuenster:
Very detailed and accurate small airport in the centre of Switzerland with two grass runways
and a helipad close to the famous place Lucerne with the newest textured airport buildings
and some surrounding industrial buildings, a church, and a chapel made all by digital
photographs. Static aircrafts and gliders, smoke effects, NDB 531 (Berm) and visual
approach charts are available. It works now fine with Fs2004. ®
pfaffnau heliport:
A small very accurate heliport in the Swiss country side of Heli Gotthard with elevated
helipad, surrounding buildings all made with digital photographs. All textures are with
full night lightning. Static cars, trucks and roads are included. It's our second heliport
of the SWISS HELICOPTER DESIGN GROUP. It works now with FS2004 (tree textures). ®
und tavanasa heliport:
A small very accurate heliport in the Swiss mountains of Air Grischa with surrounding
forest. Smoke effects, static cars, trucks and corrected roads are included. It's our
fourth heliport of the SWISS HELICOPTER DESIGN GROUP. ®
ciao rolf
Bern Belp funktioniert sogar fehlerFREI im FS2002!
Gruss Patrick
@Patrick/all
habe 3 (ohne tavanasa) unter FS02 am Laufen, und alle funktionieren..
und ich muss sagen: Echt toll!!
Luzern-Beromünster kenne ich in real leider nicht, die andern sind sehr gut gemacht :)
PS: gibt es Buttwil irgendwo? bin nicht sicher, ob ich nicht irgendwo mal was gelesen habe, habe es aber nicht mehr gefunden...
@Toni: Habe nur den FS02, und dort funktioniert es wie gewohnt, wenn man die Szenerien via FS von Hand hinzufügt...
Buttwil gibts bei avsim.
Auch eine Version für den FS04!
Gruss Michael
*g* das nenne ich schnellen Service, vielen Dank, muss ich mir gleich noch mal anschauen... (resp suchen)...
aber erst mal Gute Nach...:)
kann mir jemand sagen, warum die bei mir im fs2002 nicht funktionieren.
würde mir liebend gerne hausen laden, bin mit diesem flugplatz doch ziemlich verbunden. aber bei mir klappt das leider nicht...
lg, marcel
Marcel,
wie hast Du denn den Flugplatz installiert?
Ich habe einfach das Zip in einem temp geöffnet, die entsprechenden Files in scenery resp. textures kopiert und dann das neue Verzeichnis (z.B. .../ADOON SCENERY/HAUSEN/) im Flusi neu eingebunden.
hallo dominic
ich habe nichts anderes gemacht. aber liegts daran, dass ich fs2002 habe? jedenfalls finde ich dann den flugplatz nicht ,wenn ich ihn suche... weder unter hausen, noch unter lszn...
lieber gruss, marcel
Seit Ihr sicher, dass die Plätze nicht funktionnieren?
Wahrschleinlich laufen diese fehlerfrei, werden lediglich im Auswahlmenu nicht angezeigt......
--> fliegt doch mal hin!
Gruess Brünu
Hoi zäme,
Hausen ist nicht in der Liste, da müsst ihr eben so richtig hinfliegen, VFR halt :D
ja, richtig, daran ist es gelegen.. hab mir nun mal eine cessna startklar gemacht in wangen lachen rwy 08 und von dort mal richtung zugersee geflogen.. und siehe da... plötzlich taucht also nördlich zug eine piste auf, die vorher da nicht war.. alles i.o. in dem fall
besten dank.. und dennoch, gibts einen trick, hausen in der liste aufzunehmen?
Dahin fliegen, sauber landen und den Flieger abstellen. Anschliessend den Flug abspeichern!
--> so kannst Du immer wieder auf Deinem Flugplatz starten :)
Gruess Brünu
*grins*
tja, ich hatte bis jetzt noch keine Zeit, nachzuschauen. Stimmt tatsächlich, Hausen ist nicht in der Liste.
Der Workaround von Bruno ist ja ganz nett, aber die Frage bleibt: Weiss jemand, wie man von Hand einen Flugplatz in die Airport- Liste von MSFS aufnehmen kann??
Hallo Dominic
Ich bin kein Scenery-Designer, soweit ich weiss müssten diese Angaben aber in der BGL-Datei implementiert werden. Frag doch mal den Entwickler der Scenery...
ok, Markus, ist eine Idee!
dachte, dass es einfacher geht (à la cfg entry mittels wordpad :cool: )
habe auch mal den Heliport Pfaffnau installiert (einmal im Add-On-Verzeichniss und einmal direkt in Scenery und Texture des FS2004 und dann natürlich in der Szeneriebibliothek angemeldet.
Erschien aber nie in der Airport-Liste und auch nicht unter Add-ON-Szenerie. Gibts nur die Möglichkeit den Heliport direkt anzufliegen?
Gruss kustra
hallo
in den datei "liesmich.txt" hast du die genauen kordinaten (für pfaffnau N47:14.1467 E7:54.5318, für balzers N47* 4.23' E9* 29.27 und für die schattenalp N46:42.71 E8:12.21) nun kannst du unter dem menupunkt "umwelt" die "karte" auswählen, dort gibst du die kordinaten ein,und schon bist du genau dort. viel spass
stephan
Hallo zusammen!
Euer Thema wurde von mir natürlich mitverfolgt. Das Problem im Moment ist noch das folgende: Da ein AFCAD für den FS2004 (noch) fehlt, konnte Andreas keine Airportinfos eingeben. Somit werden die Plätze (welche nicht im Standtard vorhanden sind) nicht angezeigt. Leider muss man es machen wie oben beschrieben (VFR, direkt hin -> Flug abspeichern). Das neue AFCAD sollte diesen Herbst erscheinen, es sollte also nur eine Frage der Zeit sein bis wir für die verschiedenen Plätze updates herausgeben. Im Übrigen sind wir dran neue Szenerien zu bearbeiten (leider zieht es sich etwas, Andreas und Simon haben viel zu tun). Als nächstes werden wahrscheinlich zuerst Untervaz (bald), Gsteigwiler, sowie eventuell ein Gebirgslandeplatz (Sphinx bei Junfraujoch) geben. Seid mal gespannt...
Cheers;
Pascal
Salü Toni!
Werde ich abklären, ich gebe Bescheid sobald ich Näheres weiss.
Gruess;
Pascal
