Raffael Geschrieben 11. September 2003 Geschrieben 11. September 2003 Hallo zusammen Folgende Email habe ich von der Dutch VACC bekommen. Es geht darum, dass noch Piloten gesucht werden für einen Event. Gruss Raffael Hello sir, I am contacting you because of Friday Nite Fly-in, an event in the form of a Real Operations Night, organised by the Dutch VACC. The event will be orga- nised on Friday, the 19th of September 2003, between 1700 and 2200 UTC. This event simulates *real* aircraft movements to and from Amsterdam Airport Schiphol as on a real Friday evening. To achieve this, pilots can book 1 or more flights via our automatic reservation system on our website. Registered pilots will receive a briefing including a real flightplan for their flight(s)! The reason why I am writing to you is because there are some flights to/from Switzerland that have not been reserved yet. It would be nice if these flights could be booked by your pilots. It concerns the following flights: SWR710 LFSB EHAM SF34 SWR734 LSZH EHAM RJ1H SWR735 EHAM LSZH RJ1H SWR736G LSZH EHAM RJ1H Please forward this message to your pilots via your local mailing list or discussion forum. Flight lists can be viewed on http://www.dutchvacc.nl . Of course, pilots may feel free to reserve any other available flight too! Thank you in advance and we are looking forward to see all of you in Amster- dam on the 19th of September! Regards, Mark Jansen Events Coordinator Dutch VACC http://www.dutchvacc.nl Zitieren
Trini_Tom Geschrieben 11. September 2003 Geschrieben 11. September 2003 Hey! So wie die Flüge schon gebcuht sidn wird das hammer! Ich ahbe mein hin flug schon gebucht SWR734 von LSZH aus mal schauen was ich anchher noch fliege! Kommt auch! Das wird e hammer! Zitieren
Trini_Tom Geschrieben 11. September 2003 Geschrieben 11. September 2003 Hey nochmals! Udn nun ist auch der Letzt Flug von Amsterdam nach Zürich Gebucht! Somit ist nur noch das Leg zwischen Basel offen. ICh Freu mich schon um mein Leg zu Fliegen! Gruss Thomas Zitieren
