emmanuel Geschrieben 4. September 2003 Geschrieben 4. September 2003 hallo, vielleicht wurde diese frage schon gestellt: gibt es so etwas wie project ai für den fs2004? gruss, emmanuel Zitieren
emmanuel Geschrieben 4. September 2003 Autor Geschrieben 4. September 2003 WAS!!!!!!!!!!!!!! project ai funktioniert auf dem fs 2004. ich habe schon einen guten tag, aber diese nachricht macht ihn noch perfekter! geht AFCAD auch? Zitieren
Druide Geschrieben 4. September 2003 Geschrieben 4. September 2003 noch nicht - aber eine neue Version ist für diesen Herbst angekündigt. rgds Mike Zitieren
Druide Geschrieben 4. September 2003 Geschrieben 4. September 2003 confused, was heisst dann dies? Welcome to the Project AI AFCAD Division The Project AI AFCAD Division is here to bring the MS Flight Simulator community the best possible AFCAD designs. We have been designing RAFCADs for FS2002 for many months and fully plan on supporting the new AFCAD format for FS2004 as soon as possible. In case you are wondering, some of the things we are looking forward to in FS2004 are: overlays no longer needed to activate multiple runways, being able to assign gates to airlines without having to use the radius system. Also, runways and taxiways will have a new weight limit setting, so might be able to do something with that. We've been spending the last several weeks getting ready for FS2004, which is one of the reasons we finally decided to put together a website dedicated to AFCAD files. Hopefully you will find the website easy to navigate and we plan on filling it up with a lot more designs as soon as some new tools for FS2004 come out. If you'd like to help out with the AFCAD Division send an email to wayne@projectai.com, we're always looking for new members. No experience needed, just a willingness to learn, have fun and help out. Also, we will still continue to support RAFCADs for FS2002 on a limited basis. We will continue hosting RAFCAD files here, some of our designers may continue to release new RAFCADs, and we will continue to accept user submissions. However, our main focus will be moving toward the new FS2004 format. This website is brand new, so please let us know if you find any problems or have any suggestions on how to improve things. Otherwise feel free to browse around. Matt Fox Project AI AFCAD Division Head Modified : Mon, 01 Sep 2003 10:50:03 GMT und aus der FAQ: Will FS2002 AFCADs and RAFCADs work in FS2004? No, Microsoft completely redesigned the AFD system for FS2004 so any AFCADs or RAFCADs made for FS2002 will not work with FS2004. Will AFCAD work in FS2004? No, not in it's current version. Lee Swordy is working on a new version which should be ready sometime in October if all goes according to plan. Will we be able to convert a FS2002 AFCAD file to FS2004 format? I highly doubt that will be possible due to the major changes that have been made. However, according to Lee, future versions of AFCAD might provide a method to export an airport in XML source format. ??? PS wir reden von AFCAD nicht von PAI - die hab ich alle geinstet, logisch funzt die ;-) Zitieren
Anderl Geschrieben 5. September 2003 Geschrieben 5. September 2003 Hallo zusammen, d.h. aber dann doch wohl, dass PAI nur mit der Default Scenery funktioniert oder ? GAP1-3 wird dann wohl Schwierigkeiten machen. Andreas Zitieren
Druide Geschrieben 5. September 2003 Geschrieben 5. September 2003 aber was heisst Probleme. die Flugzeuge taxeln halt einfach in der Luft, durch die Gates und landen auf dem Gras neben der Piste, als ob der FS04-Original Airport vorhanden wäre. Genauso ist es wenn Leute online verschiedene Szenerien benutzen. Für AI kriegst du nächstens ein Update, ob die neue Squawkbox das Problem angeht weiss ich nicht. cheers Mike Zitieren
