17.07.2022 | UR-CIC | Antonov 12BK | Meridian Aviation | Engine fire, crash near Kavala(GR)
(Die Infos sind z.Zt noch spärlich)
Laut der TV Station ERT ist die Frachtmaschine auf dem Flug von Serbien nach Jordanien über Griechenland in eine Notlage geraten ("engine failure(s)").
Das Radarsignal verschwand 10NM W des FLP Kavala, wo die Maschine notlanden wollte.
Es wird von einem Grosseinsatz der Feuerwehr in Palaiochon (?) berichtet, wo durch den Absturz ein Weizenfeld im Brand ist.
https://cdn-www.airliners.net/aviation-photos/photos/9/4/6/0127649.jpg
Bearbeitet von cosy
Die Infos die ich gesehen habe sagen An-12, UR-CIC von Meridian Aviation.
 Aviation Safety link
Fred
Fred
aha, die TV Station verwendete ein Bild der Mriya (AN-225), das, wie jede-r weiss nicht sein kann. in Kommentaren zum Report wurde von Abonenten auf die AN-124 verwiesen..
danke
cosy
http://avherald.com/h?article=4fbc119a&opt=0
Zitat
A Meridian Ltd. Antonov AN-12BK, registration UR-CIC performing flight MEM-3032 from Nis (Serbia) to Amman (Jordan) with 8 people on board, was enroute at FL210 over the Aegean Sea when the aircraft began to lose altitude, the crew reported engine trouble, and turned around towards land in Greece. The aircraft attempted to land in Kavala (Greece) but impacted ground about 17nm west of the airport and burst into flames. Rescue teams found no survivors.
Sources within the Greek Civil Aviation Authority reported the crew reported engine problems and requested to divert to Kavala (Greece). However, the contact with the aircraft was lost on approach to Kavala.
Ground observers reported the aircraft appeared to have been on fire while still airborne, the fire appeared to have expanded from the engine onto the wing. After impact a fire ball rose above the aircraft.
Emergency services report that although it is unclear what the aircraft was carrying they treat the freight as hazardeous materials. Specialists are on their way to the site.
Video des Einschlags, nichts für schwache Nerven!
  • Danke 2
  • Traurig 1
  • FalconJockey änderte den Titel in 17.07.2022 | UR-CIC | AN-124 | Antonov Airlines | Engine fire, crash near Kavala(GR)
  • cosy änderte den Titel in 17.7.22 | UR CIC | AN-12 | Meridian Aviation | fatal crash
Laut Presse hatte die Maschine 11,5t Mörsergranaten geladen
  • Urs Wildermuth änderte den Titel in 17.07.2022 | UR-CIC | Antonov 12BK | Meridian Aviation | Engine fire, crash near Kavala(GR)
Hier hieß es gerade in der Presse, dass das Flugzeug Ukrainische Waffen nach Bangladesch liefern sollte und in Jordanien eine Zwischenlandung geplant gewesen sei.
edit: auf avherald steht dass die Waffen wohl serbisch waren.
Bearbeitet von Kjeld
vor 6 Stunden schrieb Kjeld:
Was in der derzeitigen politischen Weltlage eher plausibel wäre.
Warum soll die Ukraine Waffen ausgerechnet ins rußlandfreundliche Serbien zum Weitertransport nach Bangladesh liefern?
Manfred
Bearbeitet von DaMane
