ausMuenchen1 Geschrieben 24. März 2003 Geschrieben 24. März 2003 :D hallo es geht :rolleyes: die POSKY 747 fliegt ganz normal, alle Leistungsdaten stimmen...das FMC muckt auch nicht auf..sollte doch noch ein Fehler sein einfach ne Mail schreiben! Viel Spaß! hier die .cfg: [fltsim.0] title=Project Opensky - Boeing 747-400 BA CIVS sim=747-400-RR-RB-211-524HT model= panel= sound= texture= checklists= atc_airline=SPEEDBIRD atc_flight_number=092 ui_manufacturer=Boeing ui_type=747-400 ui_variation=British Airways 'Whale Rider' visual_damage=1 atc_heavy=1 atc_id=G-BNLO description=Project Opensky \nBoeing 747-400\nVersion 2002.5.6C\Ready for PSS Panel\nEngine Type RR RB-211-524HT\n\n747-400 Commercial Version\aircraft cfg by activa@tiscali.de 2003 [General] performance=Passengers\n3-class conf: 524 \n2-class conf: 416 \n1-class conf: N\/A\n\nCargo\nTotal lower hold volume:\n 5,497 ft3 (155.6 m3) \n\nDimensions\nSpan 211 ft 5 in (213 ft -- fueled)\nLength 231 ft 10 in\nHeight 63 ft 5 in\n\nEngines: RR RB-211-524HT\nTO Thrust: 58,000 lb x 4\n\nMax Fuel Cap.: 57,065 US Gal.\nMaxTOW: 870,000 lbs\nMLW: 630,000 lbs\nZFW: 545,965 lbs\nOEW: 407,107 lbs\n\nMax Range: 7305 mi \nTypical Cruise Speed \n @ FL350: M.85 atc_type=BOEING AIRCRAFT atc_model=B744 editable=0 [pitot_static] vertical_speed_time_constant=999 //Increasing this value will cause a more instantaneous reaction in the VSI [electrical] //BusType, MaxAmpLoad, MinVoltage BusTypes:0=MainBus,1=AvionicsBus,2=BatteryBus,3=HotBatteryBus,4-7=Generator/AlternatorBus(1-4) autopilot = 0, 5 , 17.0 avionics_bus = 0, 10, 17.0 avionics = 1, 5 , 17.0 gear_warning = 0, 2 , 17.0 fuel_pump = 0, 5 , 17.0 light_nav = 0, 5 , 17.0 light_beacon = 0, 5 , 17.0 light_landing = 0, 5 , 17.0 light_taxi = 0, 5 , 17.0 light_strobe = 0, 5 , 17.0 light_panel = 0, 5 , 17.0 pitot_heat = 0, 15, 17.0 additional_system = 0, 20, 17.0 marker_beacon = 1, 2, 17.0 starter1 = 0, 20, 17.0 starter2 = 0, 20, 17.0 starter3 = 0, 20, 17.0 starter4 = 0, 20, 17.0 auto_brakes = 0, 15, 17.0 hydraulic_pump = 0, 2, 17.0 fuel_transfer_pump = 0, 5, 17.0 max_battery_voltage = 28.0 generator_alternator_voltage = 28.0 max_generator_alternator_amps= 60.0 electric_always_available = 0 [Radios] // Radio Type = availiable, standby frequency, has glide slope Audio.1 = 1 Com.1 = 1, 1 Com.2 = 1, 1 Nav.1 = 1, 1, 1 Nav.2 = 1, 1, 1 Adf.1 = 1 Transponder.1 = 1 Marker.1 = 1 [direction_indicators] //1 Type: 0=None, 1=Vacuum Gyro, 2=Electric Gyro, 3=Electro-Mag Slaved Compass, 4=Slaved to another //2 Indicator number of slaving indicator if Type = 4 direction_indicator.0=3,0 [forcefeedback] gear_bump_nose_magnitude=200 ; 0 - 10000 gear_bump_nose_direction=18000 ; 0 - 35999 degrees gear_bump_nose_duration=250000 ; in microseconds gear_bump_left_magnitude=500 ; 0 - 10000 gear_bump_left_direction=35500 ; 0 - 35999 degrees gear_bump_left_duration=250000 ; in microseconds gear_bump_right_magnitude=500 ; 0 - 10000 gear_bump_right_direction=00500 ; 0 - 35999 degrees gear_bump_right_duration=250000 ; in microseconds ground_bumps_magnitude1=50 ; 0 - 10000 ground_bumps_angle1=08900 ; 0 - 35999 degrees ground_bumps_intercept1=3.0 ground_bumps_slope1=0.20 ground_bumps_magnitude2=50 ; 0 - 10000 ground_bumps_angle2=09100 ; 0 - 35999 degrees ground_bumps_intercept2=1.075 ground_bumps_slope2=0.035 crash_magnitude1=10000 ; 0 - 10000 crash_direction1=01000 ; 0 - 35999 degrees crash_magnitude2=10000 ; 0 - 10000 crash_direction2=9000 ; 0 - 35999 degrees crash_period2=75000 ; in microseconds crash_duration2=2500000 ; in microseconds [sMOKESYSTEM] smoke.0=80,-50,-90.0, fx_contrail_s.fx smoke.1=80,-50, 90.0, fx_contrail_s.fx [WEIGHT_AND_BALANCE] empty_weight = 397000 // (pounds) reference_datum_position = 0.0, 0, 0 empty_weight_CG_position = 5.0, 0, 0 station_load.0 = 0450, 81.00, 0.0, 0.0 //Weight Crew (lbs) LEAVE station_load.1 = 4000, 29.00, 0.0, 0.0 //Weight Galleys(lbs) LEAVE station_load.2 = 10000, 58.00, 0.0, 0.0 //Weight Baggage 1 (lbs) Baggage A | station_load.3 = 5000, 4.00, 0.0, 0.0 //Weight Baggage 2 (lbs) CARGO |--Max 60,000 lb station_load.4 = 10000, -50.00, 0.0, 0.0 //Weight Baggage 3 (lbs) Baggage B | station_load.5 = 8640, 58.00, 0.0, 0.0 //Weight Psgr Sect OA (lbs) First ---- |--180 lb PER PASSANGER station_load.6 = 18720, 80.00, 0.0, 0.0 //Weight Psgr Sect OB (lbs) Business | station_load.7 = 23400, 48.00, 0.0, 0.0 //Weight Psgr Sect OC (lbs) Economy A |--MAX 412 Passengers station_load.8 = 23400, -83.00, 0.0, 0.0 //Weight Psgr Sect OD (lbs) Economy B | //TOTAL ZFW = 500610 empty_weight_roll_MOI=18200000.000000 empty_weight_pitch_MOI=33100000.000000 empty_weight_yaw_MOI=39700000.000000 empty_weight_coupled_MOI=0.000000 max_gross_weight= 892365.689 [pitot_static] vertical_speed_time_constant=999 [GROUND_REACTION] MAX_STEERING_ANGLE=70 [General] performance=Flight Dynamic file by Johan Dees\nFS2002 Version 3.5\n\n\n atc_type=Boeing atc_model=B744 editable=0 [fuel] Center1=0.000000,0.000000,-4.000000,20731.000000,3.000000 LeftMain=-5.000000,-35.000000,0.000000,18870.000000,3.000000 RightMain=-5.000000,35.000000,0.000000,18870.000000,3.000000 fuel_type=2.000000 number_of_tank_selectors=1 [Flaps.0] type=1 span-outboard=0.500000 extending-time=48.000000 system_type=1 flaps-position.0=0.000000,0.000000 flaps-position.1=5.000002,0.000000 flaps-position.2=10.000004,0.000000 flaps-position.3=15.000006,0.000000 flaps-position.4=20.000009,0.000000 flaps-position.5=25.000011,0.000000 flaps-position.6=30.000013,0.000000 [GeneralEngineData] engine_type=1 Engine.0=-24.000000,-68.333333,-4.500000 Engine.1=-2.500000,-38.333333,-2.500000 Engine.2=-2.500000,38.333333,-2.500000 Engine.3=-24.000000,68.333333,-4.500000 fuel_flow_scalar=1.000000 [Reference Speeds] flaps_up_stall_speed=200.000000 full_flaps_stall_speed=160.000000 cruise_speed=593.555189 [keyboard_response] elevator=150.000000,250.000000 aileron=150.000000,250.000000 rudder=350.000000,250.000000 [Views] eyepoint=86.801284,-2.499077,16.160700 [GeneralEngineData] engine_type=1 Engine.0=-24.000000,-68.333333,-4.500000 Engine.1=-2.500000,-38.333333,-2.500000 Engine.2=-2.500000,38.333333,-2.500000 Engine.3=-24.000000,68.333333,-4.500000 fuel_flow_scalar=1.3 [autopilot] autopilot_available=1 flight_director_available=1 default_vertical_speed=1800.000000 autothrottle_available=1 autothrottle_arming_required=1 autothrottle_takeoff_ga=1 autothrottle_max_rpm=90.000000 pitch_takeoff_ga=8.000000 use_no_default_pitch=1 // 0 = Default to current pitch mode, 1 = No default pitch mode. use_no_default_bank=1 // 0 = Default to Wing Leveler mode, 1 = No default bank mode. [direction_indicators] direction_indicator.0=3,0 [EFFECTS] wake=fx_wake water=fx_spray dirt=fx_tchdrt concrete=fx_sparks touchdown=fx_tchdwn, 1 [contact_points] //0 Class <0=none,1=wheel, 2=scrape, 3=float> //1 Longitudinal Position (feet) //2 Lateral Position (feet) //3 Vertical Position (feet) //4 Impact Damage Threshold (Feet Per Minute) //5 Brake Map (0=None, 1=Left, 2=Right) //6 Wheel Radius (feet) //7 Steer Angle (degrees) //8 Static Compression (feet) (0 if rigid) //9 Max/Static Compression Ratio //10 Damping Ratio (0=Undamped, 1=Critically Damped) //11 Extension Time (seconds) //12 Retraction Time (seconds) //13 Sound Type //14 Airspeed limit for retraction (KIAS) //15 Airspeed that gear gets damage at (KIAS) point.0 = 1.000, 67.333, 0.000, -13.850, 2181.102, 0.000, 5.812, 78.480, 0.859, 0.500, 0.518, 11.000, 11.000, 0.000, 0.000, 0.000 point.1 = 1.000, -12.583, -18.000, -13.833, 2574.803, 1.000, 5.812, 0.000, 0.602, 0.500, 0.551, 14.900, 14.900, 2.000, 0.000, 0.000 point.2 = 1.000, -12.583, 18.000, -13.833, 2574.803, 2.000, 5.812, 0.000, 0.602, 0.500, 0.551, 17.100, 17.100, 3.000, 0.000, 0.000 point.3 = 2.000, -49.000, -102.900, 7.000, 787.402, 0.000, 0.000, 0.000, 0.000, 0.000, 0.000, 0.000, 0.000, 5.000, 0.000, 0.000 point.4 = 2.000, -49.000, 102.900, 7.000, 787.402, 0.000, 0.000, 0.000, 0.000, 0.000, 0.000, 0.000, 0.000, 6.000, 0.000, 0.000 point.5 = 2.000, -92.667, 0.000, -2.000, 787.402, 0.000, 0.000, 0.000, 0.000, 0.000, 0.000, 0.000, 0.000, 9.000, 0.000, 0.000 point.6 = 2.000, 88.167, 0.000, -5.750, 787.402, 0.000, 0.000, 0.000, 0.000, 0.000, 0.000, 0.000, 0.000, 4.000, 0.000, 0.000 point.7 = 2.000,-132.667, 0.000, 55.500, 787.402, 0.000, 0.000, 0.000, 0.000, 0.000, 0.000, 0.000, 0.000, 8.000, 0.000, 0.000 point.8 = 2.000, -14.917, -69.500, -7.000, 787.402, 0.000, 0.000, 0.000, 0.000, 0.000, 0.000, 0.000, 0.000, 9.000, 0.000, 0.000 point.9 = 2.000, 14.917, -39.167, -11.000, 787.402, 0.000, 0.000, 0.000, 0.000, 0.000, 0.000, 0.000, 0.000, 9.000, 0.000, 0.000 point.10= 2.000, 14.917, 39.167, -11.000, 787.402, 0.000, 0.000, 0.000, 0.000, 0.000, 0.000, 0.000, 0.000, 9.000, 0.000, 0.000 point.11= 2.000, -14.917, 69.500, -7.000, 787.402, 0.000, 0.000, 0.000, 0.000, 0.000, 0.000, 0.000, 0.000, 9.000, 0.000, 0.000 static_pitch= -1.000 static_cg_height= 13.125 // Nose gear //point.0= 1.000, 67.333, -1.500, -15.333, 1181.102, 0.000, 2.000, 70.000, 1.859, 2.500, 0.518, 9.000, 11.000, 0.000, 240.000, 280.000 //point.1= 1.000, 67.333, 1.500, -15.333, 1181.102, 0.000, 2.000, 70.000, 1.859, 2.500, 0.518, 9.000, 11.000, 0.000, 240.000, 280.000 // // Main Wing Gear (left) //point.2= 1.000, -7.583, -18.000, -17.133, 1574.803, 1.000, 2.000, -13.000, 2.602, 2.500, 0.551, 12.900, 14.900, 2.000, 240.000, 280.000 //point.3= 1.000, -7.583, -14.000, -17.133, 1574.803, 1.000, 2.000, -13.000, 2.602, 2.500, 0.551, 12.900, 14.900, 2.000, 240.000, 280.000 //point.4= 1.000, -2.583, -18.000, -17.133, 1574.803, 1.000, 2.000, -13.000, 2.602, 2.500, 0.551, 12.900, 14.900, 2.000, 240.000, 280.000 //point.5= 1.000, -2.583, -14.000, -17.133, 1574.803, 1.000, 2.000, -13.000, 2.602, 2.500, 0.551, 12.900, 14.900, 2.000, 240.000, 280.000 // // Main Wing Gear (right) //point.6= 1.000, -7.583, 18.000, -17.133, 1574.803, 2.000, 2.000, -13.000, 2.602, 2.500, 0.551, 15.100, 16.400, 3.000, 240.000, 280.000 //point.7= 1.000, -7.583, 14.000, -17.133, 1574.803, 2.000, 2.000, -13.000, 2.602, 2.500, 0.551, 15.100, 16.400, 3.000, 240.000, 280.000 //point.8= 1.000, -2.583, 18.000, -17.133, 1574.803, 2.000, 2.000, -13.000, 2.602, 2.500, 0.551, 15.100, 16.400, 3.000, 240.000, 280.000 //point.9= 1.000, -2.583, 14.000, -17.133, 1574.803, 2.000, 2.000, -13.000, 2.602, 2.500, 0.551, 15.100, 16.400, 3.000, 240.000, 280.000 // // Main Center Gear (left) //point.10= 1.000, -18.583, -8.000, -17.133, 1574.803, 1.000, 2.000, 0.000, 2.602, 2.500, 0.551, 13.400, 14.900, 2.000, 240.000, 280.000 //point.11= 1.000, -18.583, -4.000, -17.133, 1574.803, 1.000, 2.000, 0.000, 2.602, 2.500, 0.551, 13.400, 14.900, 2.000, 240.000, 280.000 //point.12= 1.000, -12.583, -8.000, -17.133, 1574.803, 1.000, 2.000, 0.000, 2.602, 2.500, 0.551, 13.400, 14.900, 2.000, 240.000, 280.000 //point.13= 1.000, -12.583, -4.000, -17.133, 1574.803, 1.000, 2.000, 0.000, 2.602, 2.500, 0.551, 13.400, 14.900, 2.000, 240.000, 280.000 // // Main Center Gear (right) //point.14= 1.000, -18.583, 8.000, -17.133, 1574.803, 2.000, 2.000, 0.000, 2.602, 2.500, 0.551, 11.500, 17.500, 3.000, 240.000, 280.000 //point.15= 1.000, -18.583, 4.000, -17.133, 1574.803, 2.000, 2.000, 0.000, 2.602, 2.500, 0.551, 11.500, 17.500, 3.000, 240.000, 280.000 //point.16= 1.000, -12.583, 8.000, -17.133, 1574.803, 2.000, 2.000, 0.000, 2.602, 2.500, 0.551, 11.500, 17.500, 3.000, 240.000, 280.000 //point.17= 1.000, -12.583, 4.000, -17.133, 1574.803, 2.000, 2.000, 0.000, 2.602, 2.500, 0.551, 11.500, 17.500, 3.000, 240.000, 280.000 // //Scrape points //point.18= 2.000, -49.000, -102.900, 7.000, 787.402, 0.000, 0.000, 0.000, 0.000, 0.000, 0.000, 0.000, 0.000, 5.000, 0.000, 0.000 //point.19= 2.000, -49.000, 102.900, 7.000, 787.402, 0.000, 0.000, 0.000, 0.000, 0.000, 0.000, 0.000, 0.000, 6.000, 0.000, 0.000 //point.20= 2.000 -92.667, 0.000, -2.000, 787.402, 0.000, 0.000, 0.000, 0.000, 0.000, 0.000, 0.000, 0.000, 9.000, 0.000, 0.000 //point.21= 2.000, 88.167, 0.000, -3.750, 787.402, 0.000, 0.000, 0.000, 0.000, 0.000, 0.000, 0.000, 0.000, 4.000, 0.000, 0.000 //point.22= 2.000, -132.667, 0.000, 55.500, 787.402, 0.000, 0.000, 0.000, 0.000, 0.000, 0.000, 0.000, 0.000, 8.000, 0.000, 0.000 //point.23= 2.000, -14.917, -69.500, -7.000, 787.402, 0.000, 0.000, 0.000, 0.000, 0.000, 0.000, 0.000, 0.000, 9.000, 0.000, 0.000 //point.24= 2.000, 14.917, -39.167, -11.000, 787.402, 0.000, 0.000, 0.000, 0.000, 0.000, 0.000, 0.000, 0.000, 9.000, 0.000, 0.000 //point.25= 2.000, 14.917, 39.167, -11.000, 787.402, 0.000, 0.000, 0.000, 0.000, 0.000, 0.000, 0.000, 0.000, 9.000, 0.000, 0.000 //point.26= 2.000, -14.917, 69.500, -7.000, 787.402, 0.000, 0.000, 0.000, 0.000, 0.000, 0.000, 0.000, 0.000, 9.000, 0.000, 0.000 // //static_pitch= -1.000 //static_cg_height= 13.625 [TailHook] // For opening cargo door. tailhook_length=1 ;(feet) tailhook_position = 0.0, 0.0, 0.0 ;(feet) longitudinal, lateral, vertical positions from datum [folding_wings] // For opening main deck cargo door. wing_fold_system_type = 4 ;0=None fold_rates = 0.05,0.05 ;Percent per second cable_force_adjust = 1.0 [flight_tuning] cruise_lift_scalar = 1.0 parasite_drag_scalar = 1.0 induced_drag_scalar = 1.0 elevator_effectiveness = 1.0 aileron_effectiveness = 1.0 rudder_effectiveness = 1.0 pitch_stability = 1.0 roll_stability = 1.0 yaw_stability = 1.0 elevator_trim_effectiveness = 1.0 aileron_trim_effectiveness = 1.0 rudder_trim_effectiveness = 1.0 [TurbineEngineData] fuel_flow_gain=0.001900 inlet_area=98.000000 rated_N2_rpm=29920.000000 static_thrust=56750.000000 afterburner_available=0 reverser_available=1 [airplane_geometry] wing_area=5650.000000 wing_span=210.833333 wing_root_chord=26.833333 wing_dihedral=7.800293 wing_incidence=0.999756 wing_twist=0.802002 oswald_efficiency_factor=0.828610 wing_winglets_flag=65281 wing_sweep=0.000000 wing_pos_apex_lon=0.000000 wing_pos_apex_vert=0.000000 htail_area=1470.000000 htail_span=73.166667 htail_pos_lon=-190.000000 htail_pos_vert=0.000000 htail_incidence=0.000000 htail_sweep=0.000000 vtail_area=830.000000 vtail_span=32.848135 vtail_sweep=0.000000 vtail_pos_lon=-190.000000 vtail_pos_vert=5.833333 elevator_area=350.000000 aileron_area=222.000000 rudder_area=247.000000 elevator_up_limit=30.000013 elevator_down_limit=30.000013 aileron_up_limit=30.000013 aileron_down_limit=30.000013 rudder_limit=33.231552 elevator_trim_limit=30.000013 spoiler_limit=70.000030 spoilerons_available=0 aileron_to_spoileron_gain=3.000000 min_ailerons_for_spoilerons=9.969466 min_flaps_for_spoilerons=0.000000 [sMOKESYSTEM] //Aileron tip vortecies smoke.0=0, -30.167, -86.167, Opensky_vortex smoke.1=0, -30.167, 86.167, Opensky_vortex //Wing condensation smoke.2=0, -08.917, -39.167, Opensky_conden smoke.3=0, -08.917, 39.167, Opensky_conden [LIGHTS] //Types: 1=beacon, 2=strobe, 3=navigation, 4=cockpit, 5=landing light.0 = 1, 65.200, 0.600, 19.100, Opensky_beacon , light.1 = 1, 13.500, 0.000, -7.080, Opensky_beacon , light.2 = 2, -49.000, -102.900, 13.150, fx_strobeh , light.3 = 2, -49.000, 102.900, 13.150, fx_strobeh , light.4 = 3, -122.700, -0.250, 12.300, Opensky_nav_yellow , light.5 = 3, -122.700, 0.250, 12.300, Opensky_nav_yellow , light.6 = 2, -121.900, 0.000, 11.450, fx_strobeh , light.7 = 3, 84.850, 0.000, 14.850, fx_vclighth , light.8 = 3, -111.500, -4.500, 43.750, Opensky_wing_light , light.9 = 3, -111.500, 4.500, 43.750, Opensky_wing_light , light.10= 5, 18.700, -29.200, -2.000, Opensky_nacelle_refl , light.11= 5, 18.700, 29.200, -2.000, Opensky_nacelle_refl , light.12= 5, 51.500, -11.700, 0.000, Opensky_nacelle_refl , light.13= 5, 51.500, 11.700, 0.000, Opensky_nacelle_refl , light.14= 5, 57.500, -13.700, 1.900, Opensky_nacelle_refl , light.15= 5, 57.500, 13.700, 1.900, Opensky_nacelle_refl , light.16= 5, 83.333, 0.000, -2.000, Opensky_nacelle_refl , light.17= 3, 72.300, -6.500, 6.000, Opensky_nacelle_refl , light.18= 3, 45.610, -4.500, 6.000, Opensky_nacelle_refl , light.19= 3, -47.510, 0.000, -3.000, Opensky_wing_light , Zitieren
ausMuenchen1 Geschrieben 24. März 2003 Autor Geschrieben 24. März 2003 :D die Angaben über die Gewichte werden vom Flusi selbst verändert, weil der Load Editor ist natürlich auch nutzbar! Gruß :p Zitieren
HF3221 Geschrieben 24. März 2003 Geschrieben 24. März 2003 Heyyyy!!!!! Was sollen......... denn immer diese............. langen Einträge hier :confused: :confused: :confused: Kleiner Scherz :D:D:D:D:D Danke für das Posten der CFG, werde es gleich mal in meinem Hangar ändern, dann klappt es auch mit der Nachbarin. ;) Schönen Gruß Stefan Zitieren
ausMuenchen1 Geschrieben 25. März 2003 Autor Geschrieben 25. März 2003 :eek: Hi Stefan, und schon getestet? Funktioniert es? Bitte um kurze Nachricht :p Gruß K.A. Zitieren
