MartinM Geschrieben 4. Februar 2019 Geschrieben 4. Februar 2019 (bearbeitet) Nachdem X-Plane 11.30 vor kurzem erschienen ist, kam nun das versprochenen Update um diverse Fehler zu beheben welche im XP 11.30 offen blieben. https://www.airdailyx.net/article/x-plane-11-31-by-laminar-research-released/ Zitat Fixes for networked external visuals. XPD-9784, XPD-9824 New datarefs for snow & experimental FM. XPD-9789 Fixes Celsius/Fahrenheit switch on the 172’s clock instrument. XPD-9790 Taxi/Landing lights do not illuminate night scenery in 3D cockpit view. XPD-9814, XPD-9825 Fixed Intel GPU HDR compile. XPD-9820 Removed custom scenery earth.wed files from new installs. XPD-9826 Fix white PFD on 737 after plugin loads it. XPD-9830 Fix for XPLMGetNavAidInfo. XPD-9831 Cirrus CG fix. XPD-9840 Default landing lights still illuminate the cockpit at night in VR Non-HDR. XPD-9843 Fixed flashlight in HDR + VR. XPD-9844 Added some gain to the pilot channel to make it louder. XPD-9848 Fix livery change on cockpit objects. XPD-9850 Crash when entering a long string into the ICAO field on the flightplan dialog. XPD-9853 Networking recognizes VPN again. XPD-9854 Fix for crash in autopilot code. XPD-9855 Heat Blur Misaligned on Multi Monitors of Different Sizes. XPD-9860 2D panel viewport set up fixed. XPD-9865 Fixed Baron heat blur. XSG-6635 This is a compromise taking published site coordinates but ignoring Jeppesen published course. Yesterday we shipped 11.31. Unfortunately this isn’t the end of X-Plane 11.30 bugs, and in two cases, 11.31 appears to have introduced new problems. We are working now on X-Plane 11.32, and our rough plan is: Fix all the really serious bugs (crashes, performance so bad you can’t fly) and ship that ASAP. Fix the rest of the lingering 11.30 bugs. Flieger die bei XP-11.30 nicht sauber funktionierten, gehen hier auch nicht besser. Bearbeitet 4. Februar 2019 von MartinM 2 Zitieren
FalconJockey Geschrieben 4. Februar 2019 Geschrieben 4. Februar 2019 Gerade installiert und einen Hüpfer mit der ZiboMod geflogen, lief. Zitieren
MartinM Geschrieben 5. Februar 2019 Autor Geschrieben 5. Februar 2019 Bei mir lief der XP11.30 prima, 11.31 auch. Gestern habe ich gewagt FXAA einzuschalten. Das gibt mir 32 fps. Ich habe ein ruckelfreies Fliegen in VR. Oculus Tray Tool SuperSampling: 1.5 Asynchonous Timewarp: Auto NVIDIA CPL Vorgerenderte VR Bilder: 2 Thread Optimierung: Ein V-Sync: Aus X-Plane Grafik HDR An FXAA Schatten Aus Thread Optimierung ist bei 11.3x offensichtlich ein FPS zugewinn, wenn eingeschaltet. Zumindest die vielen positiven Meldungen lassen darauf schliessen. 1 Zitieren
DaMane Geschrieben 4. September 2019 Geschrieben 4. September 2019 (bearbeitet) Gerade auf YT entdeckt: Innsbruck - circle-to-land RWY 08 - phantastische Szenerie klick Gruß Manfred Bearbeitet 4. September 2019 von DaMane Zitieren
